Previous in Forum: Troubleshooting a Scroll Compressor   Next in Forum: Mold Undercrust for Snap-In Enclosure
11 comments
Engineering Fields - Mechanical Engineering - New Member Technical Fields - Technical Writing - New Member
Good Answers: 21
Non metallic materials for pipe line operation
04/30/2009 9:28 AM
Gents
Please advice if is possible to use non metallic materials for pipe line operation and recommend some producers for this components.
Thanks to all
Look over to the next challenge
Re: Non metallic materials for pipe line operation
04/30/2009 9:37 AM
Could you give more information like:
What goes in the pipes?
What pressure do they work under?
Where will the pipes run: underground, on piperacks...?
Dreams are the blue print for reality.
Good Answers: 21
04/30/2009 9:43 AM
The fluid could be crude oil, diesel or gasoline, pressure will not exceed 30 barg and the location will be underground.
Thanks for your help
05/06/2009 5:04 AM
I have no experience of hydrocarbons in non-metallic pipelines, but quite a lot in firewater - underground - service. Properly specified, manufactured and installed they can be very reliable. The problems come with joining, pressure testing, inspection, proper covering, joining of standpipes, hydrants etc etc.
Inspection criteria and methods for the joints is for me a major shortcoming - I understand what I am looking at when I see a good quality Xray of a weld, with the non-metallics I only get a visual - does not give me a warm fuzzy feeling for hydrocarbon service, but then what do I know?
I definitely would not discount it, but would need some convincing. Also not sure how useful an intelligent pig or some such thing would be for inspecting such a line?
04/30/2009 9:42 AM
Flow rates?
Estimated size?
Good Answers: 21
04/30/2009 9:51 AM
The flow will be not more than 500 cubic meter/hour and the size about 24 inches.
Thank you for support
04/30/2009 10:22 AM
I have done some NDT on "Plastic Pipelines" before. I know that they do have a wide variety of advantages (and also disadvantages). I know that there are a lot of companies in Africa that use these plastice pipes on various projects. I think you will be surprised to see how many companies can help you if you google + "plastic pipes".
04/30/2009 10:26 AM
Are you out of your mind??????????????????????
What is a "barg"?
Good Answers: 62
04/30/2009 10:53 AM
No, and a garbled pressure standard or pressure for pirates Baaaargh!
05/06/2009 4:55 AM
It is not garbled - it is a standard measure used by most of the world's population.
04/30/2009 12:54 PM
bar = unit of pressure
g = gage pressure (above atmospheric)
barg = bar gage
Good Answers: 21
05/04/2009 1:09 AM
Please inform yourself before to say...out of mind!
Register to Reply 11 comments
Anonymous Poster (3); edignan (1); lyn (1); Mikerho (1); Quobaldt (2); user-deleted-1104 (3)
