Previous in Forum: Crushing Lumps of Hard Material   Next in Forum: Mositure Control
11 comments
Temperature-Activated Polymer
11/21/2006 8:02 PM
Maybe my title is incorrect--but I am searching for a material that will increase its size in at least one axis when ambient temperature falls below 34 degrees F. It needs to be environmentally stable and safe, compatible with ordinary tire rubber, and suitable for manufacture in large quantities of individual small units. Any ideas?
Re: temperature activated polymer
11/21/2006 8:03 PM
Try water it becomes ice and will do all you want!
11/21/2006 8:35 PM
That was surely a very witty reply. It certainly does point out the inadequacy of my original question. I should have noted that the material I am seeking needs to be a stable solid at ordinary environmental temperatures outdoors in the temperate zones of our planet. In addition I need an expansion factor of 30% or so.
Another way to accomplish the required action might be with a material that is very compressible down to about freezing and then becomes quite solid by about 28 degrees F., but this is a second choice. Again the material to meet the above environmental specs. Thank you for your response.
Good Answers: 75
Re: Temperature-Activated Polymer
11/22/2006 11:42 PM
I doubt there is a substance in the universe, known or unknown, that would give you the 30% expansion over the negative temperature gradient you are suggesting. I could however be wrong and am interested in what others have to say about it.
11/23/2006 12:00 AM
I would have to concur. Maybe some of that stuff Alice had on the other side of the looking glass.
Good Answers: 32
11/23/2006 12:29 AM
Such technology you can not expect for free. perhaps if your company has funds then talk to some technology developer or ORNL www.ornl.gov for help as they may help small industry research. Materials and technology one purchase for money. Possibilities are worked out for a need if funded. Imposible is something that is always pushed a bit to create space.
11/24/2006 1:44 PM
Not what I hoped to hear but thanks much for the input everyone.
Good Answers: 32
11/24/2006 10:47 PM
For increasing the volume, the structure need to be bigger and harder and forming by itself and also rapidly and N number of times without losing property. This you can achieve using bimetal strips forming cavities in the material. In bimetal one side bending is possible with increase or decrease of temperature. How you are going to do it again is your part of the research. I have given you a possibility which sure gives you a direction.
Metal can also be replaced with similar organic material. Look for strong material - fiber which can form a force that can withstand the pressure. Each of us who starts research takes just such threads in mind and tries ideas by design.
You have posed a very nice problem. You get five points for that.
Good Answers: 32
11/24/2006 10:53 PM
Another solution is to sense the temperature and heat the material externally or internally using embedded heaters. This thing may be easly possible and within the reach of an engineer to design a method. However it will require energy. Internal heating can prevent wastage of energy.
Good Answers: 18
11/27/2006 5:45 PM
With absolutely no idea how this will utimately be used, I would look to existing products that are mechanically actuated based on temperature.
The two that come to mind are bi-metal elements and wax-piston motors. Both have been mass produced for automotive applications in thermostats - originally the bimetals, and recently more wax-pistons.
The wax piston requires more space (as currently developed), and requires some kind of mechanical coupling to apply the force in the opposite direction to the expansion of the wax, since you apparently want something to be pushed (rather than pulled in) as the temperature DEcreases (inverse actuation). On the plus side, the wax can be custom formulated to operate at a selected temperature range, and most are nearly solid as a polymer at near-freezing temperatures, and can apply great force over small distance.
For small size and durability, go bi-metal. The metal alloys are selected for temperature response in the range you need, with member length and attachment dependent on the actuation displacement required.
If you can run 12VDC to this as a circuit...you can always use a bi-metal as a snap-action switch that activates the circuit in a mini wax-motor with a heating element inside.
Try these guys:
www.ark-les.com/products/custom-products/actuators-wax-motors/default.html#wax
Call it 'half empty' or 'half full' if you must, I've got the other half in a redundant glass...
11/27/2006 10:39 PM
This is of interest to me--thank you very much. I will educate myself somewhat on the subject of "wax motors".
Lon
Good Answers: 32
11/27/2006 11:00 PM
Yes, this wax motor idea is nice one.
The link is OK and I looked at noth hot and cold activated wax-motors.
Five points to this information.
Register to Reply 11 comments
Anonymous Poster (1); lshurtle (3); masu (1); rcapper (1); Sandman (1); Shyam (4)
