Previous in Forum: what welding parameters should i suggest to weld with SMAW   Next in Forum: Vacuum Pump Performance Curve
LEAD ANGLE
05/02/2009 10:08 AM
What should be the helix angle for M15x1.0 & M18x1.0 metric threads??
Please reply to darshanautomotive@airtelmail.in
Re: LEAD ANGLE
05/02/2009 12:59 PM
Good Answers: 137
Re: LEAD ANGLE
05/05/2009 6:28 AM
What bolts are these? I don't think M15 is made (though there may be a design for it). M18 is available but is non-preferred (M16 and M20 are preferred).
And pitch is not 1mm. Pitch of coarse metric bolts is usually 1/8 nominal dia. (M16 has pitch 2mm, M20 2.5mm). Metric coarse threads are normally used, fine is special. Fine is about 1/10 nominal dia. if I remember right, I haven't got the data to hand.
Cheers........Codey
Re: LEAD ANGLE
05/05/2009 9:38 AM
It seems fairly obvious that the threads are non std or "bastard" threads.
Here's a fairly comprehensive list of threads arranged by size.
Good Answers: 137
Re: LEAD ANGLE
05/05/2009 10:01 AM
Useful list! I thought after posting that I'd jumped to the conclusion he was talking about bolts, when he hadn't said so. There are also metric electrical threads which have different nominal sizes from (preferred) bolt sizes, and have much smaller pitch than bolts.
Cheers..........Codey
Re: LEAD ANGLE
05/05/2009 1:12 PM
"There are also metric electrical threads which have different nominal sizes from (preferred) bolt sizes, and have much smaller pitch than bolts"
Yup ..Fine metric threads might well be the norm in electrical applications or other specialised areas.
Glad you liked my threads page.
