Previous in Forum: Designing an Earth Mat   Next in Forum: ac or dc ? / Halogen bulbs
Overvoltage in a Mains
05/04/2009 9:29 AM
Dear all,
I have come across a curious fault in a system on 11kv 3 phase 3 wire, supplied from the electricity company to distribution transformer 200kva - 275 mtr. away, & connected by 3c * 150 sq mm XLPE UE grade Under ground cable.
During a day time, operations are normal, voltages are normal - 400V 3 phase, 4 wire on LT side. Power capacitors of 20kvar * 3 nos. are connected fixed to thr distribution board. & are continuously ON.
We have provided a neutral contactor with the mains MCCB for DG change over.
What we have found that the coil of the Neutral contactor burns frequently, abnormally. Definitely, due to over voltages.
What could be the reason of such over voltages?
Exploring the Science of Electricity
Re: Overvoltage in a Mains
05/04/2009 11:43 AM
During the day when the load is high you utility voltage is normal. At other time the voltage is high because the load is low. The utility voltage regulation is lacking. Also the capacitors will cause a voltage rise when they are on line. You may want to measure the voltage with the cap off line and see it it helps.
05/04/2009 2:11 PM
pls mention about your loads (what type of loads are you loading 1 phase or 3 phase). in case if single phase loads more than three phase loads this type of problem may happen. as you mentioned that magnetic netural contactor burning frequently. this type of problem happening because of temperature increasing on that contactor(core, coil etc., i think contactor coil slowly getting weak and making problem). check the return current as well as contactor rating suitable for return current.
05/05/2009 1:18 AM
dear,
contactor coil rating is 240v ac. proper.
LOAD ON SYSTEM : < 100 kva , transformer rating 200kva
nature of load : welding machines 15kva * 10 nos. , 20kva * 4 nos. , 8kva * ^ NOS>
05/05/2009 12:58 AM
Check the load on each phase & balance the load.
05/05/2009 7:12 PM
Harry
You have the answer to your question. Measure the voltage at peak loads, light loads and light loads with the capacitors off line. Then we can discuss the problem.
Anonymous Poster (1); harry potter (1); uticobala (1); wareagle (2)
