Previous in Forum: Dye Penetrant Testing and Fluorescent Particle Disposal   Next in Forum: Anaerobic Digesters for Methane Production
26 comments
Energy Storage - The Key to Renewable Energy?
05/04/2009 5:27 PM
Hi Folks
There are numerous means of non-fossil power generation which are dependent on season, weather, time of day or other 'suspensive conditions' . The generation of energy is not reliably continuous, there may be not enaugh energy available when it is required. This is often used as an argument against solar or wind power.
I feel that the storage of energy is a major factor in getting renewable energy sources into wide acceptance.
My idea is, to use a thermally insulated ( underground) water tank of, say, 50,000 to 100,000 liters as a long term heat storage for the average residential house. Heating the body of water via a solar system, or with other types of free energy.
The stored energy can then be recovered to heat the house on cold days or at night time, heat up tap water, or can be converted to electrical energy by means of an ORC generator as and when needed.
Now, I'm not that familiar with the units of 'specific heat' and so forth and would like to see the calculations you guys and girls can come up with.
Average energy requirement for heating a family home in Germany should be around 15000 kWh per year. How would that tie up with the heat storage capacity of a water tank of aforementioned size, if the water is heated by 40 degrees via a solar collector, biogas, or other free sources. How long would a single temperature increase of the whole tank's content last, what is the minimum temperature drop over time, which is achievable with low-tech (low cost) insulating technologies?
Any information on the efficiency of ORC power generation systems which can work on such small heat differences?
Looking forward to your input.
Regards, Hangwaiter
Re: energy storage
05/04/2009 8:32 PM
http://cr4.globalspec.com/thread/26331#comment277006
Regards JD.
Re: energy storage
05/04/2009 9:12 PM
In my semi/un-educated opinion the most user friendly method of storing energy is to convert it to potential energy and then transfer it back. This has been done on a grand scale in the Snowy Mountain Hydroelectric scheme in Australia, where the system acts as a buffer, put simply, when there is an excess of output from another plant, the system activates a number of heavy duty pumps which pump the water from a lower reservour below the dam back up behind the wall.
Now water turbines are rather efficient, but the pumps not very much so, however the principle of storing mass amounts of energy has already been proven to work in this form. So this could be implemented say for a solar plant where energy needs to be stored during the night.
However i have doubts about the feasability of major power generation coming from wind or solar sources, simply due to the energy required to make them in the first place.
Not remembering the source, but from fuzzy memory, a solar panel which has a 25 year life span running in average conditions, requires approximately 10 years of its life to pay off the energy taken to produce it; this means that if we were to change to solar completely in 10 years time, we would need to more than double the energy currently being produced by our exhisting systems (not feasable) for these 10 years, and 10 years of these life would be spent paying off the energy requirements of the next series.
I know this is a real downer for many people, but in our current situation, if global warming is a real fenomenon, the only realistic solution which can be considered is using nuclear energy for the transition period into renewables. However, that being said we need to dig into the renewable research as soon as possible to make sure that when the time comes to implement them that we are prepared.
Re: energy storage
05/05/2009 4:08 PM
Hi Guest
Thanks, very informative. I've got your point on the Nuke, but also raise the question of how much energy is required to build a nuclear plant plus a suitable waste disposal facility, plus the energy to produce the fuel, plus the resources required to run the reactors, maintenance, safe dismantling and disposing of the plant after its service life has expired and so forth. Maybe this is not any more efficient than a solar collector, just more spectacular and more viable for politician's interests?
Hangwaiter
Re: energy storage
05/05/2009 1:13 AM
Sounds workable to me. Over here in the US, we already use geothermal heat pumps. An aquifer maintains a year-round temperature of perhaps 10 degrees C. In summer when the temperature is 25 degrees C, the aquifer makes a much more efficient heat sink than the 25 C air and saves on air conditioning costs. In winter when it is -25 C, a heat pump can still extract heat from the 10 degree water.
With your idea, a storage system with high enough temperatures to run an ORC generator might not be practical on a single house scale. Figure the surface area of the tank, the R value of the insulation, and the temperature differential, and you can calculate the losses over time. The volume of a storage vessel increases geometrically while the surface area increases linearly- that's why whales are as big as they are- thermal efficiency. So the bigger the tank, the lower the losses per liter. As far as insulation goes, a foot or two of plain old compressed fiberglass would be fine- the more insulation, the better the efficiency, so figure that into the long term capital cost.
A landfill would be a perfect site for one of these systems. Bury the tank in the landfill, and the thermophillic reactions (same reason a compost pile gets hot) will reduce the temperature gradient. Burn the flare gas in a boiler and heat the water in the tank. On top of the landfill is a good spot for low-tech solar collectors, too- surprising how much heat you can get out of a black plastic pipe suspended 1 cm above a sheet of white plastic and covered with clear plastic.
Using refrigerant instead of water as a thermal fluid will allow the hot water in the tank to yield electrical or mechanical energy as well as thermal- this system is already being used for low-temp geothermal power. It can be operated in reverse to take the lower temperatures of the solar collectors and heat the tank to 100 C. On peak demand, cut the gas flare heat over to the ORC generators temporarily, then go back to heating water when demand drops. A million litres of water can store a lot of energy- that's 4180 joules per degree c per liter, plus at 100 c you can store 2,260,000 joules per liter before it boils.
Good luck with your idea.
Good Answers: 62
Re: Energy Storage - The Key to Renewable Energy?
05/05/2009 10:28 AM
I had tackled this when I still had disposable income and a house I could theoretically experiment on
But while there are efficiencies to be gained "going bigger", what you actually need for sizing this thing is the general period that evacuated solar water heating tubes are not effective. So the number of days you cannot collect solar. You'll be surprised how few.
So in New Mexico (yes it not only gets cold - it snows) our average "coast period" was less than three days. So awful and overcast we couldn't collect solar.
Now, part of this mandates evacuated solar tubes, which aren't cheap, but are stunningly efficient.
Some of this is available from whomever signs your local building permits / zoning authority / or even heating professionals.
You need to know "insolation? days" which are mapped world-wide and available from solar resources on the web.
You need to know what in the US they refer to as the "Design Temperature" which is very localized (so off to the zoning office), and indicates the temperature equivalent of the 100 year flood for temperature. It is that 90th percentile cold temp reflected in your area.
And then as part of the mechanical design you will need some reflection of the snow loading - so grab this at zoning, too.
Then once you have heated your house, how to get energy out of the excess you have stored? Gotta tell you I hadn't cracked this one. I wanted a Sterling engine, but the only commercially produced ones are going to the desert for years to come, and they haven't even projected a consumer price.
So I'll go back to lurking and see what the community can come up with.
05/05/2009 4:07 PM
Hi Edignan
Thanks for your comprehensive reply! As for the recovery of energy out of my storage tank, I thought of using an Organic Rankine Cycle system - essentially a heat pump - which does require power input to run, but is capable of shovelling the heat out of the storage fluid with ease.
Meanwhile I came across an article about a franchise supermarket store owner, who uses hot water pumped into deep well drilling holes to store energy.
The heat is the excess temperature produced by his aircon and refrigeration units. the heat stored in the underground water ( it's not even in a tank!) serves to heat the store for the whole winter. Seeing that the shop is in Germany, we are looking at least at 4 months of heating requirement. I could not find out, how much hot water they pump down into the well, and how the water is kept there.
Good Answers: 62
05/05/2009 4:15 PM
Damn - wish I'd a thought about heat pumps
But I was really trying to get away from blown air as all my ducts had collapsed. So my goal was radiant heat (actually radiators rather than in-floor) with hot water.
So direct circulation worked for most my needs, but with all that infrastructure installed I wasn't satisfied just heating the house.
Problem was, no one "shot the engineer" and just heated the house.
05/05/2009 10:46 PM
An ORC system doesn't necessarily require external power. If your heat source is hot enough to boil the thermal fluid (refrigerant, in the case of low-temp heat extraction) in the evaporator, it can drive a turbine to provide output power and run its own compressor. Like a Stirling engine, you do need a heat sink to dump the heat from the condenser (such as the atmosphere.) The greater the temperature differential between the heat source and the heat sink, the more power available. Chena Hot Springs Resort in Alaska converted from diesel generators to low-temp geothermal power.
05/06/2009 3:32 AM
The biggest problem in changing the typical home heating installation is the level of knowledge of the installers.
They don't want these complex systems. Just put a gas/oil burner and traditional central heating system and you're done.
In theory an underfloor heating system already safes approximately 10%, just by reducing the water temperature. But typically an installer doesn't understand this and will put the temp higher and adds a reducer/mixing valve (you need hot water from the tap, so you need the high water temp level)
What you need is controllers and decent programming, ask this from Joe the Plumber.
In theory a normal home could be heat supplied with 60.000 liter of water and a delta between 70 and 30°C.
You will need a heat pump to generate the hot potable water.
But if you play it a bit more intelligent you can replenish the vault as soon as wind is blowing or the sun shines.
Again this is a mixture of techniques which can only be managed by engineers.
Another technique which can be used is latent energy storage: a paraffin which melts at 64°C stores the heat of the solar panels and gives it back at the constant solidification temperature. Different types of paraffin can be used to maintain different levels of heat.
There even exist systems to keep the mobile phone stations cool: store the heat in melting paraffin and re-use this during the night to keep the panel at the wanted temperature. as soon as the day starts the excess heat is than rapidly exchanged with the still cool surrounding air.
But these systems are more expensive than traditional air conditioners (at least to buy it initially) so you seldom see it installed.
So it is simple: money keeps the whole world from using intelligent systems.
But it is not so far away in history that Joe the Plumber was convinced that insulation was thrown away money.
Give me the basis to experiment a bit and I will build you a system which can turn each home into a passive House, without the special architectural jokes. (but adequately insulated)
Good Answers: 62
05/06/2009 8:57 AM
Points very well made, while I wanted to build something efficient; I also wanted to ensure it was something I could put back on the market, and that could be maintained by the local plumber.
I figured some combination of partnering (I needed a qualified plumber to sign off and that gives the next owner "the plumber" to call) as well as automating as much as possible, but also really robust design and diagnostics.
But while I was serving "my" needs; in the back of my head was the commercial impact. The competition has a couple of boxes every HVAC or plumbing guy knows how to install, they may not be efficient but they are largely immune to design and installation flaws, and they are relatively cheap and dependable.
Tough competition.
05/06/2009 9:19 AM
Here comes the design engineer in the whole product creation process: there is still a lot to do to make a system which is installable by a local plumber.
But it is feasible, the only problem is that you will have to dig in a reservoir of 20m³ to be filled with paraffin. The tank must be thoroughly insulated (300 mm of PUR at least) and secured against floating.
Sometimes the heat reservoir is build in the house: all heat loss goes to the house so in fact is not to be seen as loss. But, you can only do this when it consists of a new house and when it is architecturally feasible.
For renovation you will have to find way's to build the storage in the house (the attic or the basement)
A self learning black box will have to do the complete trick of managing the heat flow.
Ideally I would combine this with a vertical axis windmill, without the inverter and heating up the paraffin when wind is blowing, this would enable the owner to work with a smaller amount of paraffin. (how small? that is what field trials have to show)
Good Answers: 62
05/06/2009 9:29 AM
And worth throwing into the mix - for a general solution cooling must be considered.
Arizona's major energy expense is not heating, it is cooling all those houses empty during the day.
05/06/2009 9:42 AM
No problem, but who the hell lives in Arizona?
Good Answers: 62
05/06/2009 10:08 AM
Only morons, but there are quite a few of us.
But better, the solution applies to all peoples living between the sub-tropical zones.
05/06/2009 10:24 AM
First off, water is a very good choice look at the table of specific heat capacities further down this Wiki article: water has the highest specific heat capacity per unit volume of any known substance.
http://en.wikipedia.org/wiki/Specific_heat_capacity
And in response to the pump the water to a higher reservoir camp, do the sums: you have to lift (pump) 420 litres of water 50 metres to store the same amount of energy as heating 1 litre of water by 50 degrees C.
But why stick at a hot water reservoir, if you use a Vertical Axis Wind Turbine (VAWT) to directly drive a compressor you can simultaneously heat and cool two tanks of water. Most energy used in a modern home is used in either heating or cooling: you can use the hot water and cold water almost directly via heat exchangers to do this.
There is one thing better than the specific heat capacity of water, and, that's the specific latent heat of fusion of various substances. You can considerably reduce the size of the required tanks by using some of these. On the cold side use a tank filled with salt water but mostly filled with flexible containers (polypins/wine containers) full of water/ice. On the hot side fill the tank with ordinary water, but, take up most of the volume with flexible containers full of paraffin liquid/wax.
The one problem here is that you will have to get your ORC (for the electrical requirements) to work on a temperature differential of 0°C to between about 60 and 80°C (depending on the paraffin you choose).
05/06/2009 11:53 PM
As has been pointed out, running the numbers is needed not on just the 'engineering' side, but the economic side of the equation.
I worked for a oil company for years. A IROI (Internal Return on Investment) of 18% was required to even think about considering a project. This included the 'risk adjusted' costs for drilling 'wildcat' wells for exploration, and anything else including solar (which they did some of as a PR thing as well as to keep their hand in other technologies, just in case).
If I see the 'oil' companies start investing is a different technology, without government subsadies, then I will be pretty well convinced there is money to be made that is REAL money profits and not just 'wished for' profits.
... Of the technologies I have seen so far, the 'algae' growing seems the most reasonable to me. ... It would allow 'pressing' the algae to get some oils, and then either sequestering the remaining algae carcass (basically cellulose) for carbon sequestration, OR digesting it and breaking down the cellulose to sugars to make ethanol from (so it is not using a food sources), OR feeding it to animals or even humans ground as 'flour'. - It also recycles almost 100% of the water, and consumes carbon dioxide. Currently they are enriching it from 'other co2 sources' rather than from the air only to enhance production. Using it from the 'air only' would be my preference. Currently major sources of 'commercial co2' are from CO2 wells or as a by-product of other process including occasionally burning fossil fuels to get the CO2 ... counter-productive if we are trying to reduce the CO2 in the atmosphere.
To do this being a reasonable greenie at heart, I might suggest investing in solar to run the electrical required to make this thing work, but I wouldn't feel bad if it wasn't.
Again, the economics on this seem as good as most. ... Short term, wind is winning because it is 'shovel ready' many places, a known and easy to install technology. ... I am guessing we will have more 'tax incentives' to skew the economics of installing solar like we did in the Carter administration. This will spur some real installations, and draw a lot of shylocks into the 'sell/install' world again just trying to 'consume' tax give-a-ways, rather than solve a problem.
Even a good technology has its ney-sayers. But the money in the long run follows the truth. It is diverted or accelerated to the 'truth' by tax incentives, but at a minimum it is re-directed by them.
I may sound pesamistic about the future and our 'leaders', but from my experience it is just 'once shot, twice shy' experience. ... Just like my saying about stock and bond brokers, 'if it calls you on the phone, it is not an investment'.
05/07/2009 4:11 PM
Hi all contributors
Thanks a stack for all the input, I wish this would carry on further, even the off-topic comments are worth the effort.
I am leaning heavily towards thinking that we are all taken for real fools. I recently bought a 17 year old little 4x4 hatch ECVT-Automatic ( Subaru Justy KAD), which drinks just over 5 liters of regular per 100km (measured)
Now, if the Japanese engineers were able to do this, why are we (17 years later!) still manipulated into thinking that a petrol consumption of more than twice this is just ok for the latest models on the market?
My Dad owned a 1968 Fiat, 1,6 DOHC, Sedan with the aerodynamics of a barn and the weight of a tractor. Consumption: Around 9 liters per 100 Km ( and that measured in 1990, when the car was already 22 years old and had severe mileage on the clock)
Now, where's all the technological advance which had to happen in 40 years? Adding airbags and tons of unnecessary electronics, and a more modern look can't be it! In my opinion we should have been able to discard the ICU completely or at least build cars which use no more than 2 liters per 100km.
what do you think? Will gladly open a new thread if there's interest
Good Answers: 204
05/08/2009 12:41 PM
you are so right ! GA
05/08/2009 4:19 PM
I totally understand the perspective, and not to 'protect' the auto industry, but we are comparing apples and oranges.
In the 40 years, our vechicles weigh less, (my full size station wagon that I could put a full size sheet of plywood down flat in, totally inside, and it fit BEHIND the drivers area) weighed considerbly more than my current 2001 Ford Ranger. My ford ranger cannot carry a sheet of plywood flat in its bed, and the box is the long box and is about 2' short to be able to put it in the box. The station wagon had a 318cu in inch V8, and got about 20 to 25 MPG. The Ford Ranger gets about 30MPG (measured). The wagon could cruse all day above 100MPH, and the Ranger can't hit but 70 going down hill with a tail wind. It also has a small, Hitachai, engine.
I am sure the 1963 Dodge 440 model station wagon was MUCH worse on polution than the Ranger is. It could also carry 6 people with ease and a lot of camping gear. My Ranger carries 2. The Dodge wagon had a PVC valve but that was it, no catilytic converters or anything.
Your Subaru is 'full time 4 wheel drive', with the latest polution controls, and may or may not have a larger engine than the Fiat your Dad had. His had NO polution controls. Your Subaru propbably has fuel injection, and your Dads was carburated. He NEEDED to change oil every 3K miles, and you can go 7K (by most mfgrs specs), but I would not do it if I wanted to keep the vehicle running).
After working around the 'oil patch' I know the fuels are different. No lead now days, the fuel is 'cracked finer' and more of the 'light aeromatic hydrocarbons' are removed (because they can be sold as other products for more $$, and you will not know or ususally care). Your new vechicle has thinner metal and more light weight construction and plastic than the Fiat.
Safety issues have also changed the construction (and cost) of vehicles.
And then are we comparing needs or wants. Do we NEED as much transportation as we use? Do we make decisions to use it whether we need it or not?k
I can't figure it all out. ... I used to like getting a full tank, and heading out to 'explore the back roads with my honey or family. We don't do that anymore.
Our society has changed, and our vehicles have too.
IF someone figures out a really better way, I am all for it. We can then look back on ICU as specialty engines like we see steam today.
I want batteries that last the life of my vehicle, make it weigh the same or less, need recharging only every 300 miles, the car has charging cells built into the structure to reduce (not necessarially eliminate) the need for external charging. Have public 'charge stations' that charge by the columb of charge with micro-payments, and the stations can be ubiquitous. (have parking spots with inductive coils in given 'charging spots', and card/coin operated payments). ... I want the car to be crashworthy when run up against other vehicles AND trucks. ... I wouldn't mind a battery car with a 'single wheel trailer' that carries a propane tank and small ICU that runs a generator to charge the batteries on the cars command for long distance runs.
I want a better system than we have using trucks for long distance travel. Containers are much cheaper to move, even if trucks do the 'last miles'. How about having non-long distanct trucks convert to propane or cng (compressed natural gas). Even doing that with cars would save lots of wear on the ICUs today.
... And then even if these products exist, 'will the buyers come'? I like the philippines answer. If your car is over X years old, pay a tax annyally or turn it in to be crushed. After Y years the tax rate goes up by an order of magnitude, until all that is left is 'show cars' and 'antiques', which could be un-taxed if they are driven under 100 miles a year (or pick a number).
... enough of solving the worlds problems. ... back to surfing the net' :)
Good Answers: 62
05/07/2009 4:26 PM
Well....
I recently (this decade) went digging in to figure out the mysteries of manifold fuel injection.
I see why manufacturers liked it.
Rather than drill two holes in the combustion chamber and actually meter fuel to the cylinder - they came up with the fuel rail and manifold injection. All made of plastic and firing an entire bank on a single pulse.
So a left / right firing (squirting?) sequence for my V6, and use the intake as a bucket where the fuel will wait until the valve opens.
Cheap, simple, hard to screw up - yet they DO get better mileage. Than the previous carbureted model.
05/07/2009 4:52 PM
Also a thing I did in the last decade, just for the fun of it:
On my way to work and back, I pressed the clutch pedal and let the car roll without engine input, whenever this seemed viable ( downhill, when approaching a traffic light, whenever the traffic in front of me slowed down, etc. ) With a little practice, I almost doubled my gas mileage (185%), though the engine was still kept idling, even during longer traffic jams.
This required a lot of thinking and was actually quite a lot of shifting and 'clutching to do.
Later I tried the same, but switching off the engine at every 'freewheeling opportunity", which brought me to 212% of the usual gas mileage.
Definitely not a practical way to drive, but if a little computer chip could take over the job of using the engine only when power is really required, our current gasoline wasters ( i.e. all petrol driven cars) could easily half their fuel consumption.
Let me add, that during those test drives (over 4000km) I never sacrificed safety and also did not take longer for the same driven distances. It was just annoying to always think about cutting out the engine.
Now someone tell me that the thousands of highly educated engineers in the automotive industry are unable to make such a system market ready?
Good Answers: 62
05/07/2009 5:19 PM
Hah! I ran into some of these ideas on a website flogging HHO, but also every other damned thing that might improve economy, magnets, fuel heaters, aether stirring devices and what not
Then a link to the 100% garunteed method - and a long description of just these techniques. As I was running back and forth between Albuquerque and Los Angeles I had the opportunity to test them. They work great, but as you say are very interactive i.e. a lot of work. A clutch helps a lot.
So did dropping down from 85 to 75, but I had to decode my axle rating for that choice - need a taller axle.
as to the other, "market ready" means idiot proof in this world
although if you take sensor hmmmmm
Good Answers: 204
05/08/2009 12:44 PM
not only that, but you will save yourself a thousand dollars if you don't do braking with your clutch. use your brakes and coast the clutch, as you've stated. It is far cheaper to replace brake pads than clutch pads.
Chris
Good Answers: 62
05/08/2009 1:27 PM
It certainly is on the full size Dodge diesel - brakes are maybe $75, clutch job $1400+
Hobbies - Fishing -
05/08/2009 1:15 PM
I had an '84 Honda Accord which got 40 miles/gallon. The new accords get in the mid 20's. So much for advancement...
“Sometimes I wonder whether the world is being run by smart people who are putting us on or by imbeciles who really mean it.” -Mark Twain
05/09/2009 7:37 AM
Hello,
I think you will find the following article informative. I have been very interested in this same concept for a number of years. There are a number of articles on the Internet regarding these installations in Germany.
http://www.solites.de/download/06-Eurosun.pdf
John
Register to Reply 26 comments
Anonymous Poster (3); chrisg288 (2); edignan (8); Gwen.Stouthuysen (3); hangwaiter (4); jdretired (1); lighthasmass (1); Randall (1); servant74 (2); velisj (1)
