Previous in Forum: Deaerator Water   Next in Forum: Polishing Jet Engine Blades
AIR FLOW OF AXIAL FLOW FAN
05/05/2009 12:15 AM
HOW TO CALCULATE AIR FLOW OF FOLLOWING FAN
FAN DIA= 1500 MM
FAN SPEED= 960 RPM
Re: AIR FLOW OF AXIAL FLOW FAN
05/05/2009 12:30 AM
GET A HOLD OF THE FAN PERFORMANCE CURVE
Good Answers: 58
05/05/2009 1:02 AM
You can not calculate it. You can measure it or you can look at the manufacturer's curve.
Good Answers: 70
05/05/2009 1:20 AM
As the other replies state,you can use the manufacturer's specs, that are based on set standards of air temp. density, free flow, etc. The easiest way is to just measure the air flow under the conditions that your running the fan at. That will give the most accurate CFM's
05/05/2009 3:38 AM
  1. Turn off Caps Lock.
  2. Obtain the serial number of the fan.
  3. Obtain the telephone number of the manufacturer of the fan.
  4. Telephone their technical helpline, and obtain a performance curve for the fan.
United States - Member - New Member Technical Fields - Technical Writing - New Member Popular Science - Weaponology - Organizer Hobbies - Target Shooting - New Member Engineering Fields - Nuclear Engineering - New Member
05/05/2009 9:01 AM
http://cr4.globalspec.com/thread/37227/Calculating-Air-Flow-for-Axial-Flow-Fans
Anonymous Poster (1); dj95401 (1); PWSlack (1); Steve Melito (1); The Prof (1)
