Previous in Forum: How to Size Axial Flux Alternators   Next in Forum: changing a dedicated 460 volt motor to a 230 volt motor
India - Member - New Member Engineering Fields - Electrical Engineering - New Member
Maximum Continous Overvoltage (MCOV)
05/08/2009 6:52 AM
I have follwing data for 220/33 kv substation:
system voltage-220 kv
LA rated-198kv
LA MCOV-165KV
so you see the rating of MCOV is less than its rated voltage,what does it mean?
Re: Maximum Continous Overvoltage (MCOV)
05/27/2009 3:28 PM
Someone Fthed up and under rated or ordered the wrong parts, get something thats rated for what your working with & see what the operating tolerances +/- are to factor in.
06/10/2024 9:22 AM
It's difficult to say without knowing what the abbreviations mean:
LA - Definition by AcronymFinder
MCOV - Definition by AcronymFinder
Based on the above, there are 297 possibilities.
Good Answers: 22
06/17/2024 5:53 AM
MCOV is calculated based on the maximum system voltage and adding a factor over it.
In this case 245kV is the maximum system voltage for 220kV system. Since LA is connected between Phase and Ground, the maximum voltage that appears is 245/1.732 = 141.5kV, with a safety factor of 10% required MCOV comes to 155.6kV. Thus, MCOV of 165kV translates in to 115% of max voltage that can appear across the LA and thus is more than adequate.
Only power systems which are ineffectively earthed need to have higher MCOV.
Raghunath
Register to Reply 3 comments
Anonymous Poster (1); PWSlack (1); raghun (1)
