Previous in Forum: BSEN 60660 and Switches   Next in Forum: South-Africa in need
Using a 110VAC/60HZ Heat Sealer at 110VAC/50HZ
05/11/2009 9:16 AM
Is it possible to use 150W, 110V ac, 60HZ Impulse Heat Sealer to use at 110V ac, 50HZ power supply straight without frequency converter? Do you need frequency converter? what would be spec. for F. converter?
Good Answers: 18
Re: Using a 110VAC/60HZ Heat Sealer at 110VAC/50HZ
05/11/2009 4:03 PM
Sure! The heater is resistive, so the frequency doesn't matter.
05/11/2009 7:51 PM
They're all rated at 50/60Hz anyway.
Google it.
Register to Reply 2 comments
