Previous in Forum: A valid formula for calculating a customer's usage factor for natural gas???   Next in Forum: Cheap Ethernet CCTV Cameras
17 comments
Tipi Poles
05/12/2009 2:54 PM
I have an idea for a telescopic Tipi Pole. I've considered fiberglass as the material to use. However, because of the weight and primarily the cost of fiberglass I've had to reconsider progress of this idea.
Because I am not an Engineer and I'm not sure what type of material is available, I am soliciting comments for my Tipi Pole idea that would hopefully meet the following criteria:
1. Recyclable Material (Go Green), 2. Light Weight, 3. Colorable, 4. Sturdy - Durable, 5. Long Life, 6. Mobility/Transportable - Telescopic, 7. Minimal Storage Space, 8. Low Cost, 9. Locally Manufacturable - Montana Area - If possible
The most important of the above is Recyclable Material, Light Weight and Cost. I am also not sure what Forum Thread below would be the most effective to access. Please Help :-)
Pathfinder Tags: Tipi Pole
Good Answers: 62
Re: Tipi Poles
05/12/2009 3:08 PM
Well I was totally sold on lodgepole pine except it won't telescope.
I'm left with aluminum until someone smarter comes along.
- And you posted in the best place if you have doubt.
Re: Tipi Poles
05/12/2009 3:36 PM
I also thought of Aluminum but I'm not akin to lightning :-)
Good Answers: 62
Re: Tipi Poles
05/12/2009 4:04 PM
I don't want to pass myself off as an authority on the subject, but....
I don't think aluminum is any greater a danger in the heights we are talking about than wood
And once wetted, I'd bet they are equal.
Good Answers: 39
Re: Tipi Poles
05/13/2009 2:48 AM
Wadda ya mean it wont telescope? You just have to wait a long time for it to extend. Say about 15 - 30 years, depending on what size ya want. Only trouble is you need a chain saw to reduce it in lenght and it's a one shot deal. Like so many other disposable things these days.
However on the brighter side, you can used the shortened lodgepoles pieces for fire wood at your next camp. By the time you have hunted up more lodgepole pieces the sqaw should have dinner ready over the fire.
Elnav
Re: Tipi Poles
05/13/2009 6:46 AM
Re: Tipi Poles
05/13/2009 8:40 AM
Your kind of an idiot aren't you!!!!!!!!! You must be a white guy - squaw - get real, please don't respond, you haven't contributed anything but your ignorance. Thanks anyway :-)
Good Answers: 62
Re: Tipi Poles
05/13/2009 9:08 AM
Dude, please note the indent of his message - he wasn't talking to the "thread" - that would be you - he was responding to another poster.
And we work for free - we get paid with polite
Get too cranky and the rest of us drop tools and go home.
And I am a white guy, too.
So don't know why Andy rubbed you so wrong, but try to keep a lid on your temper.
Re: Tipi Poles
05/13/2009 3:48 PM
Not me, Elnav was "funning!"
Re: Tipi Poles
05/12/2009 7:19 PM
What about socketed sections like this:
I've seen camping tent poles (fiberglass, but doesn't have to be) like this with a line of "bungee cord" running through the axes, allowing for quick assembly and disassembly.
Mike
Re: Tipi Poles
05/13/2009 8:46 AM
I've thought of this as well but to sell or market, my idea has to look authentic. As well when you have a pole that is 20 to 27 feel long this idea would tend to bow with it's shear length. Thanks for your response :-)
Re: Tipi Poles
05/14/2009 8:25 AM
Or you could use "captive" sleeves like this:-
Good Answers: 38
Re: Tipi Poles
05/12/2009 11:58 PM
You could use Carbon-fibre as an alternative
Re: Tipi Poles
05/13/2009 6:54 AM
I don't know what lengths you need but Fishing rods are made of both fiber glass and carbon fiber. You may need a few more because of thickness, but some of these are telescopic and some are butt jointed (eg. demountable).
That would be the cheap and very light way.
Flag poles of similar material are also available.....more expensive. You need to make a joining system....for breakdown.
Aluminium is a good bet, go to a tent maker or Camping supplies.....
Cheaper are steel tent poles, but heavier.....from the same suppliers....
With a trailer and a proper mounting system, you could use poles that are not demountable in any manner.....thats how people trail sailing boats around with a mast.......
Re: Tipi Poles
05/13/2009 8:51 AM
Thanks, the Carbon Fiber fishing pole is a good idea, I'm not sure if it would bow much with a 20 to 27 foot length but with a larger diameter, it's worth looking into. Thanks Again.
Good Answers: 62
Re: Tipi Poles
05/13/2009 8:16 AM
All good suggestions - but I think we need an expert to resolve his question about lightning first.
Is a 12' stick more dangerous because it is conductive?
Unfortunately lightning experts are rare.
Re: Tipi Poles
08/08/2009 1:54 AM
You could try chain link top rails or get the metal top rail sleaves and cut the poles in two. I do not think that the carbon fishing rods are a good idea. I belive that they would be to thin.
Re: Tipi Poles
06/05/2010 5:26 PM
I have the same curiousity. Especialy when I have an old Vw camper with a pop top roof that may not be able to handle the weight of pine poles. I met with a plumber with an idea that demanded an expert eye. You can get two 11 foot pvc schedule 40 poles. Get a T junction to join the two and have every second pole joined together at this junction in an 'A' frame. have two set of poles cut at 11 feet and joined in this manner. Have the next set cut at 10 feet and its partner at 12 feet and joined in 'A' frame style. Rotate them in this manner throughout the tipi. This will shift the stress points around the tipi so that the 11 foot mark will not be the weakest link. You may even place a thinner PVC pipe in the middle and super clue it into the lower pole. The top pole can slide on like a sleeve to insure strength. For example. Have two poles 11 feet each joined with a T junction. Place a 10 foot pvc pole that is thinner but with a high schedule inside so that 5 feet are in the lower pole and 5 feet in the higher pole.
You can also paint them to look like a wood colour.
These poles should last a very long time, lighter in weight, and easy to repair.
Register to Reply 17 comments
Andy Germany (3); Anonymous Poster (2); edignan (4); elnav (1); Epke (1); Mikerho (1); Nehemiah13 (4); Randall (1)
