Previous in Forum: GMAW Consumables - 516 Gr 70 Plates   Next in Forum: flare
40 comments
Solder Pad Sizes
05/13/2009 5:59 PM
I am designing a PCBa that is very populated with components and I need to solder some components with wires (by the way, It is for volume production) .
The question is, depending on the wire gauge, what is the area I must give on the solder pads?? Is there a matrix I can use that has the recomended sizes to avoid having lifted pads??
I had this kind of problems before with lifted pads when managing the cables. A specification here is to resist 2lbs of force on the cables and I am guessing this would be the same for the solder joint and also for the resistance of the solder pad to the PCBa. Whoever is the weakest will be the resistance of the assembly... I am only concentrating on the resistance between solder pad and PCBa.... but whatever information you can give me I will be eternally gratefull :)
Open your eyes, look within. Are you satisfied with the life you're living?
Re: Solder pad sizes
05/13/2009 6:49 PM
Good question.
For the standard components, the suppliers will have recommended pad sizes to follow and those are readily available on the net.
Most important for through hole solder joint strength is that you use "double sided plated through hole" type of boards. I've run experiments on the "pull through" strength of joints (lead based solder) and almost regardless of the amount of solder on the joint, it becomes a simple shear strength of the materials.
By using double sided boards, this strength is then available in both directions of force.
Second most important is to use minimum suitable clearance for the ID of the hole for the wires. Means that you get better capilliary action (wetting) through the board thickness and thus a stronger joint and also maximum area for the solder pad. (Also better with no air inclusions and impurities.)
I'm assuming that you have access to the IPC standards for through hole connections, so there are some recommendations in there.
My experience of solder pads "lifting" all associate with either excess heat/time combinations during soldering or rework OR excess mechanical force from the wires after soldering.
Excess heat/time is a matter of tuning your process properly. Mechanical force is an outcome of your wire selection, stiffness of conductors, insulation and often how far into the strands the solder has wicked during the soldering activity.
As a ballpark idea, we solder wires at a pitch that is 1.5 times the OD of the insulated wires. You can specify "oval" or other geometric shapes for the pads to reduce the risk of bridging and provide improved pad adhesion.
What are your intended soldering processes and production volumes? Maybe we can help with the necessary facility and technology.
05/14/2009 10:30 AM
Hey, thanks for the answer, it is really helpfull. It was more focused to a solder lap but we also use through holes on other pcba.
When you say you solder wires at a pitch of 1.5 times the Outter diameter of the insulated wires, you mean the OD of the wire with the jacket? or the strands combed together? oh, and the 1.5 times is for the width of the solder lap pad?
We will be soldering only cables to pcba. no SMT as we are mostly a manual assembly factory.
Good Answers: 38
05/14/2009 10:59 PM
the PCB supplier should have data on the solder pads strength and at which pull strength the pad will tear off with via holes it depends more on the solder type/quality before you tear the wire off
Good Answers: 145
Re: Solder Pad Sizes
05/14/2009 11:21 PM
I concur with Just an Engineer(GA to you).
You haven't mentioned to which of the 4 IPC classes of board you are constructing, 1C, 1, 2 or 3. Being in Mexico Class 1C (Class 1 China) isn't a relevant class for you to aspire to. Is this board for domestic class 1 or commercial/industrial class 2 or 3? This will also have a bearing on the design of the board
Also for consideration will it be manufactured with RoHS (or equivalent) materials? As the various lead free solder has different properties which will affect your assembly processes as well.
Good Answers: 15
05/15/2009 2:53 AM
Another area you should look at is "Is my new board testable"
This thought should be see in the early stages when the board is still in CAD design.
You want the PCB to be manufactured by some company, then every product 100% tested before it lands on your desk, the last thing you want is 10-20% failures cause it wasn't tested.
Can every net be tested (not on to the component leg but a special land)
Single or double sided testing
will you allow enough space on the top to counteract the probe forces acting from the bottom side of your PCB.....
Qn, Whats the differance between a Snake and a Onion? Ans, No one cries when you chop up a Snake
05/15/2009 10:44 AM
I like the way you think! DFT (design for testing) :) I will look up on this.
Good Answers: 15
05/17/2009 6:28 PM
Its my job, for the past 11-1/2 years, I have designed test fixturing for the electronics industry here in Australia and New Zealand.
The latest being for a brake lighting manufacturer in NZ, but we have done work for sheffen in Qld (well close enough to Qld..)
05/15/2009 4:48 AM
Just thinking aloud really:
If you are going to solder the wires into through holes then I wouldn't worry about strength, just make sure that your clearances are enough to avoid shorts.
If the wires are going to be attached to pads, then: in my experience of actually working (i.e. no experience of design or specification) with these sort of things, the quality (spec. method whatever) of the adhesion of the copper to the board seems to be more significant than the pad size.
05/15/2009 10:43 AM
Which takes me to another question: How much space should I give around the soldering area for manual soldering operations.
How much space from each solder pad and from other components?? I try to give as much as possible but no less than 0.8mm ... and there are still shorts on the soldering process.
The quality of the adhesion of the copper I think it is a very important factor, I will look up on that.
by the way... what happens to the early worm?
05/15/2009 11:19 AM
I'm no expert on this but 0.8 mm is definitely enough, have you got a solder resist layer?
..and there are still shorts on the soldering process..
Is there any way to get the people doing the soldering to "own" more of the process. If they get to see their own mistakes they ought to start improving.
Um, I think the implication is that it gets eaten by the early bird. (Alfred E. Neuman was that guy with the big ears on the front of MAD magazine)
05/15/2009 11:26 AM
what is a solder resist layer?? what does it look like? is it like a white marking around the pad? I have had that question for quite some time...
early worm still gets eaten hmm... its better to be the bird in every situation hehe
05/15/2009 11:43 AM
The people who make your blank PCBs will know.
From http://en.wikipedia.org/wiki/Printed_circuit_board
Solder resist
Areas that should not be soldered to may be covered with a polymer solder resist (solder mask) coating. The solder resist prevents solder from bridging between conductors and thereby creating short circuits. Solder resist also provides some protection from the environment.
_____________________________________________________________________
From http://en.wikipedia.org/wiki/Solder_mask
Solder mask or solder resist is a lacquer like layer of polymer that provides a permanent protective coating for the copper traces of a printed circuit board (PCB) and prevents solder from bridging between conductors, thereby preventing short circuits. Solder mask was created primarily to facilitate wave soldering used in mass assembly. The solder mask is most often applied with a green tint but is available in a wide variety of colors and finishes. It also provides some protection from the environment.
Solder mask comes in different media depending upon the demands of the application. The lowest cost solder mask is epoxy liquid that is silkscreened through the pattern on to the PCB. Other types are the liquid photoimageable solder mask (LPSM) inks and dry film photoimageable solder mask (DFSM). LPSM can be silkscreened or sprayed on the PCB, exposed to the pattern and developed to provide openings in the pattern for parts to be soldered to the copper pads. DFSM is vacuum laminated on the PCB then exposed and developed. All three processes go through a thermal cure of some type after the pattern is defined.
________________________________________________________________________
I did a google search for:- wiki solder resist
Results 1 - 10 of about 83,200 for Wiki solder resist. (0.28 seconds)
http://www.google.co.uk/search?hl=en&q=Wiki+solder+resist&btnG=Google+Search&meta=&aq=f&oq=
Looks like a lot of other useful links.
08/24/2020 7:55 AM
The information is too good to understand the PCB's soldering and soldering masks. Thanks
05/15/2009 7:29 AM
Go to website Cutler-Hammer, look for "design.pdf". On page 31 you will all your questions answered about pad size in relation to hole size for double sided as well as single sided PCB's. Drill 2 holes, slightly bigger as the insulation of the wire you using, in line with your solder pad. Feed your wire through one hole than back again through the next and solder in pad. Cheapest and most effectful strain relief. Regards, Dieter
05/15/2009 10:28 AM
where is this document? I can't find it...
05/15/2009 3:24 PM
Hello Guest,
could not find the design.pdf on the cutler-Hammer website (eaton electrical). Which country website are you referring to?
Good Answers: 38
05/17/2009 9:06 PM
maybe it is this one ? Link
Anyway i was wondering Manufacturing Jedi, what is your job exactly? because it strikes me odd that you don't know what a solder resist layer is when you are designing something. or is your factory mostly assembly work?
05/18/2009 10:26 AM
You got me. I meant to say we are designing, the design team is composed of electrical, mechanical, manufacturing etc etc. I am a manufacturing engineer and apply the design for manufacturing principles.
Also please remember that my primary language is spanish and somethings are named different. I knew solder mask but not solder resist layer... sheeshh, cut me some slack here.
05/18/2009 10:42 AM
Don't get upset, none of us knew your background.......stay cool!
Your English fooled us into thinking that you were first language English, a compliment!
Good Answers: 38
05/18/2009 8:38 PM
it was just a question. It puts things in perspective i hope the link is useful to you.
I know the most important sentence in Spanish "un Cervesa por favor" and some swearing words of course (everybody should learn foreign swear words they'll come in handy ).
05/15/2009 10:05 AM
Whenever possible I recommend using a connector on a board instead of just soldering single conductor wires to a board. This will distribute the mechanical load to multiple solder connections, some of which will not have a signal on it. I do recognize that there can be valid reasons to not use a connector though.
05/15/2009 10:39 AM
yeah, I like connectors also but they are too expensive. we are trying to cut down on costs and 30 to 40 cents is a lot of money from the unitary cost of our product.
05/15/2009 11:42 AM
This sounds like a penny wise and pound foolish concern. If you only look at the cost of the raw material, then you should be using copper ore, sand, and crude oil. When you include labor costs, the cost of a technician hand soldering a wire will easily be more than 30 to 40 cents per wire.
But you're now delving into the art of design. Deciding which corner can be cut to improve profit and marketability versus which cut corners will just make you bleed.
Have Fun!
05/15/2009 12:27 PM
I think it depends on where your production is... in mexico I really doubt labor cost can keep up with material costs.... if you consider we take 20 seconds to solder a cable and an operator costs 3 dollars an hour... that means that we spend around .016 dollars in that operation VS having a connector that costs 30 cents (including the one on the pcba) and also having to connect it (4 seconds) which costs you .003 dollars...
Ofcourse there is scrap costs and quality costs but we can manage those with a good control over production processes.
1 cent over a 1Million a year production = 10000 dollars a year
25 cents is a quarter million . A lot more I make a year :(
It would be very different if I was in europe where production labor cost is like 20dlls an hour...
A 20 second operation would cost you 11 cents!!
05/15/2009 1:11 PM
I see that I've hit a sore point. My apologies, I did not intend to wound.
But one of the lowest costs associated with any worker anywhere is their pay. Yes several of the other costs do scale with this pay, but to base your cost reasoning solely on the hourly wage of one worker and the time to complete one part of a task will always give false information.
Let me put this a different way, one of the most cut throat in cost cutting industries is the manufacturer of computers. While it is true that most of the chips are now soldered to the board instead of socket-ed. Very little to no discrete wires are soldered directly to a board. The few that are soldered to a board, are wave soldered on one end to a board and connectorized on the other end.
Why do you think they do that?
05/15/2009 2:02 PM
No, not at all :) its ok. I agree, it is false information, I think it is twice or 3 times higher than what we think the cost is.
For the computer example, I think it is a different solution, mainly because those PCBa's need to be reconnected over and over again for service and repair. This is not our case but you touch a good point there, if you need to repair or service a product then you need to make it as reworkable as possible.
05/15/2009 3:46 PM
I once worked for a company that went crazy/happy if someone saved 10 cents on a PCB production, even though it cost us 10 dollars more to replace in the field....
Seen it time and time again.....some people never learn....
The aim must be to save the company as a whole money, not just one department!!! and especially not to up costs in another department!!!!
With some US companies, reason is not a strong point!!
05/15/2009 4:00 PM
Andy,
Those same guys will be bitching while on the unemployment line that sales couldn't get their cheap products sold. Perfect example, Mercedes Benz is still respected for fine quality automobiles. Their expensive but they do sell. Chrysler, well their not as expensive...
To quote the Kinks, "The one thing about it, cheap is cheap."
05/16/2009 6:42 AM
Very well put.....
My company went "Tits up" because each department fought to cut its cost, even though it raised the costs several 1000% in other deoartments.... Connectors on PCBs were a prime source of such problems, which were replaced with wiring that needed to be taken out that went all over the machine with many tie wraps to cut and replace.....
I have SH*T better engineers than such that cause such havoc......to save 30 cents on a proper connection system......
A company must look at cost savings for the company as a whole, not just one department. I even offered to uprate the whole output of one particular PCB at my own cost for the years usage for the whole domestic and international usage, it would have cost me around $100........and saved many thousands of $$$$ in time and parts at the customer...... It was not allowed......
The engineers in question are invariably just out of the Uni as they are the only ones who will work for the poor pay sometimes offered.......older reliable Guys with experience cost real money......
It all boils down to cost saving in the wrong places, by the wrong people.....for the wrong people!
Good Answers: 15
05/17/2009 6:37 PM
There are not many companies around these days that don't try to cut corners and save even just 5-10 cents by leaving out part from production..
The newer car I have now, "Holden VE Calais" there is supposed to be a plastic cover over the front of the engine to over the radiator, the mounting points are there, but they saved money by leaving this out, only a few cents for each car.
Then you get the total savings...
no product to manufacture, transport, store, install, no special assembly tools or mounting hardware....
They saved thousands, I would have paid the extra few cents to have it there ;o(
05/15/2009 10:14 AM
I would not solder wires directly if you have had pad lifting problems, that means that they are too highly stressed mechanically....
I would use proper screw connectors, properly soldered, in a row, where the soldered joints all work together to withstand a pull on any wire.....
Here are a few examples:-
05/15/2009 12:20 PM
Just my two cents...I have just recently gone through something similar.
I too am a Engineer by accident and have little to no actual knowledge of standards etc...
But this is what I do.
When soldering wires into a through-hole ALWAYS use solder pads on both sides of the board. Even if your design is single sided. Make it a double and put pads on both sides. Much stronger. And I generally just use a .1 header and change the hole and pad size to match the AWG of the wire.
When using just a pad to solder to. I always try and make the pad as long and skinny has possible so there is as much surface area to solder to as possible. Depending on the location and number of wires (in a row) you can also epoxy the wires to the pcb just below the solder connections. I have also used a hole for a wire tie to help with strain relief. Make the hole like this ---- ( | ) So you can run the tie around the middle section and then around the wires. This works great if you have the room
Or you can do what I just did. I just encapsulated the board in Epoxy...Problem solved!
This is what I have done in the past...Hope it helps.
bill12780
I'm fix'in to do somethin' stupid as hell...But I'm gonna do it anyway.
Good Answers: 12
05/15/2009 4:27 PM
Addressing the lifting of pads: If the board real estate allows, consider adding an extra hole for each wire which is oversized to accept the insulated wire. Thread the wire through the larger hole and then into the hole with the solder pad. The larger hole works as a strain relief. It also assures that the wire will not have solder wicked up into the area that needs to be able to bend.
The problem with connectors with low tech assembly is that they require operators to strip and crimp the wires to exacting standards. They require in process inspections and equipment calibrations as it is often not possible to inspect or test for failures on fully assembled connectors. Was the crimp made with the right tool? Is the crimp free of wire insulation? Etc. Failure to do so introduces failure points.
I agree with Manufacturing Jedi that soldering wires directly to the board may be best. In this situation it could be both the lowest cost and the most reliable solution.
05/15/2009 5:36 PM
It could be a fierce horrible monster!
But it's just a bunny.
It could be a fierce horrible bunny monster, with fangs.
But seriously, I'm suspicious of anyone who asks for basic knowledge like how large of a hole to make for a wire. If one is doing their own personal prototyping, try different clearance diameters and test for suitability. If you've been hired to design this part, you should already know where to find this out. Particularly if one claims millions of pieces of product. I would certainly expect somebody advising on the fabrication techniques of a circuit board would know what a solder mask is. I do agree that some circuit boards don't require a solder mask. But one has to know what something is to consciously choose if it's necessary or superfluous.
The first post (Justanengineer I think) clearly stated that the failure mode of a soldered wire to a board is typically not from the land being pulled off of the board. For most wires soldered to a circuit board are done with a plated through hole. When done in this fashion the sharp bend radius experienced by the mechanically unsupported wire now becomes the weakest link, not the land on both sides of the circuit board. If our OP does start using a plated through hole instead of tack soldering, he may find that the pull that is ripping the lands off of the board, may instead snap these wires. My point here is that the problem is not hole size or solder quality, or cost. The problem is that something is pulling on this wire and one must either anticipate this force with an assembly that can take it or accept that you make a crappy product.
A redesign to be cost effective must at least solve one problem.
05/16/2009 6:45 AM
You marked yourself off topic. Why?
I have added a GA to make it slightly better/correct...
You were right on the money for me anyway.......
05/17/2009 8:13 PM
Back from a short break.
For soldering onto surface pads instead of through hole, the challenges are very different. Management of strain from the cable into the solder joint is your primary concern.
I understand your cost constraints and sometimes even the design constraints will prohibit use of through hole wire system.
suggestion: Make the orientation of the board such that the wire does not "peel" the pads form the substrate. The cable entry should be parallel and directly in line with the solder pads so that the only way they can come off the board is through "shear".
Clarification of previous remark: spacing of 1.5 times sheath diameter is the pitch of the centre lines of the connections. Anything closer than that would present significant challenge to soldering. The difficulty with 0.8mm (between pad) clearances bridging suggest that you have either a larger cable/strand bundle or "poor wetting" of the soldering process. (I am assuming that you have solder resist between the pads.) What is your conductor size and I'll mock something up here to try it out.
The bridging sounds like poor solder tip selection, cold iron, poor flux, contaminated solder pads or whatever else is stoping the solder from wetting into the joint. It could even be that your solder wire is too big in diameter for the task. I would also suggest that you have the wires pre-tinned (solder dipped) to assist in the soldering process.
Remember that the recipe for a good solder joint includes "time" for the materials to properly heat, time for the solder to be added and time for the solder to wet to form the miniscus shape relevant for the materials in use. Bridging can be an outcome of excess solder and insufficient time to allow brides to "snap away". How many wires are involved in this assembly? 30 seconds implies far fewer wires than I understood from your first information.
05/29/2009 12:12 PM
Hello,
I am designing an SMT component (header with 2 terminals) to be placed on a PCB board with surface pads. The 2 terminal component needs to withstand a 5 lb shock/vibe test in every direction with just the solder joint. I am limiting it to 2 terminals to free up board space. I am trying not to use a threaded insert through the middle of the component for added mechanical retention.
Does anyone know of any existing documentation or calculations for the mating strength of the surface mount terminal with the surface pads after reflow?
I know it will be dependent on the actual solder joint after reflow (lead free), but anything in general will help.
thanks,
Philip
Mechanical Design Engineer
Good Answers: 12
05/29/2009 12:29 PM
Guest - I recommend that you register and resubmit your comment starting a new thread so that your question will be seen by a larger audience. Very few are currently tracking this old thread.
Good Answers: 15
05/31/2009 10:46 PM
Not just the solder joint, but also the pad to substrate adheasion strength.
Personally, I wouldn't trust the pads to hold anything more than the component that is being soldered to them, more mechanical securing would be preferable, or mechanical retention of the PCB to a panel including the component to the same panel.
05/18/2009 3:57 AM
Cutler-Hammer's "design.pdf" can be found on Daan Terstegge's Website: www.smtinfo.net/Db/_DFM.html.
Good luck, Dieter
Register to Reply 40 comments
Andy Germany (5); Anonymous Poster (2); bill12780 (1); DieterB (1); Epke (3); Just an Engineer (2); Manufacturing Jedi (9); msbettyhunt (1); Randall (3); redfred (5); Snaketails (4); Snave (2); Tobugrynbak (1); Urbie (1)
