we have heater to heat the vapors for regeneration of dryers sequence is control by PLC and the heater control starts when the sequence reaches that step set value is set in plc at 340 Oc the output of the controller is 4 to 20ma and is given to SRC which drives the heater in burst mode , output of the controller reaches max value but we are unable to reach the set temperature ie we getting 328 Oc . we check the temperature element ,found tobe ok and the transmitter to be ok.
SRC has failed once and repaired by the vendor since after we are receiving this problem .
can any body tell me the reason ?? or any configuration to be checked in SRC
regards
Adil
