Previous in Forum: vibration control   Next in Forum: Belleville Springs
Steam Boiler Efficiency
05/15/2009 4:08 AM
main function of steam boiler is to release heat energy in fuel which absorbed by water .water absorbs heat and changed from liquid to steam with certain amount and pressure .
my question how to calculate fuel consumption and boiler efficiency related to product steam under different pressures.
thank you in advance
Re: steam boiler efficiency
05/15/2009 5:52 AM
Carry out an 'energy balance' on the boiler.
  • Add up all the energy streams entering the boiler in one column.
  • Add up all the energy streams leaving the boiler in a second column [for the steam conditions, consult Steam Tables].
  • Make sure the two column totals are the same.
  • From the list, select the energy leaving in the steam; divide by the energy entering in the fuel; multiply by 100%.
  • "Robert is your mother's brother".
If it's any more than 45%, then double-check the calculation.
05/15/2009 7:57 AM
thank you PWSlack .
may i need more details like , energy entering boiler is only fuel, say diesel with a rate
m. kg/hr and calorific value Cv k.cal/Kg.
so entering energy = m.* Cv in K.cal /hr ........... Am i right?
what about burner efficiency ?
how can i calculate losses in flue gases and losses due to in complete fuel combustion also any other losses which may be hidden for me .
is there a web site can gave full detail for that subject
thank you again
Haroun
