Hi, do anyone have experience with belleville springs?
I am using one (actually I have to use because of space constraint) for a application where a two ton mass is supported on four bearig blocks (in horizontal plane) thru four pins welded on it. There is an appx inaccuracy of 2mm between the axis of the pins (in horizontal plane). To take care of that & also to take care of the shock load acting on the bearing blocks during transpotation I am going to mount bearing blocks on belleville springs (properly stacked) I will be using guide rods to guide the springs as well as the bearing blocks ( to avail vertical floating).
I am using series & parallel stacking for optimum assy height & deflection.
I want to hear from people who already used such kind of arrangement.
