Previous in Forum: PVC Pipe vs. Arizona Sun   Next in Forum: Oxidation and Metal-Polyurethane Bonds
Aluminum Polishing
05/17/2009 9:53 AM
need info on how to eliminate black spots when polishing smooth aluminum casings .
thanks everyone! poppabear !.
Pathfinder Tags: metal finishing
Good Answers: 150
Re: polishing aluminum
05/17/2009 10:58 PM
Do you mean castings? If so, the black spots are most likely porosity in the casting that are picking up the dirt and grit from the polishing process. If that is the case, your only cure will be eliminating the porosity. I'd start by revisiting the casting supplier chosen and the maximum porosity limits placed on them.
Who is John Galt?
05/21/2009 6:14 PM
thanks for response, iguess i will have to grind the pits out and repolish.
Good Answers: 97
05/17/2009 11:18 PM
Require a surface condition prior to polishing conducive to provide the finish quality as specified.
05/21/2009 6:17 PM
what type of conditioner do you recommend
Good Answers: 150
05/22/2009 9:38 AM
He means specify a maximum porosity allowable. Any castings that are too porous are rejected. Continuing to buff in an attempt to buff out the porosity is likely merely to expose other porosities in the process.
Who is John Galt?
bwire (1); poppabearjules (2); Rorschach (2)
