Previous in Forum: Generator Set - Pipe Size for Fuel Lines   Next in Forum: Ramifications of NOT Grounding a Vehicle
can you put a starter from a cavalier a 1994 Corsica
05/19/2009 10:09 AM
can i put a starer from a 94 cavalier in a 94 corsica
Re: can you put a starter from a cavalier a 1994 Corsica
05/19/2009 10:11 AM
Yes, provided you can open either a door or a window. If you want it to start the engine as well then you will need to open the hood instead of one of the passenger doors or the trunk.
Good Answers: 62
05/19/2009 10:12 AM
Call a parts house and see if they are carried under the same part number
Or go online somewhere like RockAuto and see the same.
The info you need is called a parts interchange catalog, but they are not generally available - most in use by salvagers - so you could call the junk yard and ask.
05/20/2009 11:55 PM
You should be able to put the starter in because the 4 cyl. and the v-6 both use the same starter in both vechiles.
Jim
05/20/2009 11:57 PM
can i put a "starer"?
Please, spell check!
Anonymous Poster (1); edignan (1); Jspeop (1); lyn (1)
