Previous in Forum: Switchyards and Earthing Conductor Sizes   Next in Forum: Inverters for Photovoltaics
Temperature raise in 16A switches
05/20/2009 12:13 AM
1) What are the factors that influence the temperature raise in 16A switches?
2) How to controll the temperature raise in switches?
Re: Temperature raise in 16A switches
05/20/2009 1:55 AM
You may overloading your 16A switches that why the temperature raised. The only way is to reduce your load of the 16 Amp Switches or use bigger ampere switches.
05/26/2009 9:29 AM
check your terminations then use a clamp meter on to check on the current flowing on full load may be u have an overload next your switch will be gone
05/20/2009 2:37 AM
Check the cable termination and contact mV drop.
BNDas
05/20/2009 3:06 AM
What is the current flowing through these 16A switches?
biswanath.das (1); kimani (1); PWSlack (1); Simon Wan (1)
