Previous in Forum: Speed and Angels   Next in Forum: Wattage Required to Heat Acid
Voltage Fluctuations
05/20/2009 3:21 AM
A load survey was conducted to establish a recurring voltage fluctuation problem at a factory feeding from a 3 phase 750 kVA 415/240 Volts transformer. During off-peak hours, the voltage records +15 to 20% of the nominal voltage while during peak hours it records -15 to 20% of the nominal voltage.
What could be to cause of this and how do we alleviate this problem?
Thank You
Saida
Re: Voltage Fluctuations
05/20/2009 3:29 AM
Either the load fluctuations are large in comparison with the transformer's rating, or the transformer's supply cabling.
2 options come to mind:
  1. Reduce the load on the transformer.
  2. Increase the size of the transformer and/or its feeder system.
05/26/2009 6:14 AM
Thanks,
Saida
