Previous in Forum: weight calculation formulas of ms angle, chammel, beam etc   Next in Forum: Vacuum Drop - Code Requirements
LPG combustion
05/21/2009 2:39 AM
what will be air fuel ratio for LPG combustion by volume?
Re: LPG combustion
05/21/2009 3:13 AM
What are the proportions of which particular gas in LPG by volume?
Re: LPG combustion
05/21/2009 5:27 AM
I am assuming you refer to Propane. You need about 12kg of air per kg of propane for stochiometric combustion. Assuming excess air of 10% you then need 13.2 kg of air per kg of propane.
So if you know your ambient air temperature and pressure, you can work out how many m3 /hr of air you need per Nm3 of propane.
Register to Reply 2 comments
