Previous in Forum: Using ADI Information for Educational Purposes   Next in Forum: Control Valve
Butterfly vs Control valve
05/21/2009 3:48 AM
All
Some Butterfly valves can be treated as Control valve.
How can one identify them.
Thanks
Be simple and specific for a great success in Life
Re: Butterfly vs Control valve
05/21/2009 3:52 AM
A butterfly used as a control valve will have an analog actuator on it, varying the disc angle in response to a varying input signal.
05/25/2009 1:31 AM
hi
As Mr.PWSlack said it consists of an actuator and by changing the actuator stem the disc position changes this results in change in flow. Hence this is treated as Control valve. This is similar to that of Ball valve. based upon the requirement in some cases it can be used as uni-directional valve.
regards
foreveryone
South Africa - Member -
Good Answers: 12
05/25/2009 2:34 AM
Hi there,
A lot depends on the class shutoff you need. Download the fisher cotnrol valve hand book from www.emmerson.com
It will explain in a lot more detail what you need.
Regards,
Craig
India - Member - ADIL MOULA Engineering Fields - Instrumentation Engineering - Adil Moula
05/26/2009 5:29 AM
This butterflyvalves are quick opening valves and generally used for HI flow rates and less pressure drop , they can be identified as how it is installed ,6'' line size may require 4'' butterfly valves for the required flow rate because they are line size valves. Reducing the size of the butterfly valve can give a better control valve opening.this valves as better control valves on reduced pipe size , as similar yo the control valves .
refer
http://www.sbt.siemens.com/HVP/Components/Documentation/15370192.pdf
Register to Reply 4 comments
craigza (1); find2am (1); foreveryone (1); PWSlack (1)
You might be interested in: Control Valves, Gas Valves, Industrial Valves
