Previous in Forum: Butterfly vs Control valve   Next in Forum: Butterworth Filters vs. Fast Fourier
Control Valve
05/21/2009 4:35 AM
In typical installed response of linear valve will be like quick opening valve. and the equal percentage valve will be linear. can we use linear valve if we need equal percentage valve characteric response in practical?.
can any one tell me what are the criteria which determines the type of valve to be used in process lines. what typical factors to be considered to give preference to linear, equal %, and quick opening valve.
Pathfinder Tags: control valve selection
Re: control valve
05/21/2009 4:36 AM
<...what typical factors to be considered to give preference to linear, equal %, and quick opening valve...>
Control system stability at the full range of output signals.
Re: Control Valve
05/22/2009 5:25 AM
By changing Positioner Cam we may be able to change the valve characteristics,although tight control will not able to achieve
For Selecting the Valve characteristics follow the guidelines , these guidelines may vary from due to change in company standtards,
a) linear flow characteristic
when the ratio of differential pressure across the control valve at minimum flow over the differential pressure across the control valve at maximum flow is equal to or less than 1.5
when the differential pressure conditions across the control valve under all specified flow conditions are more than (2/3) the differential pressure across the control valve in the closed condition
b) equal percentage flow characteristic
for all other modulating control applications, except for those
under a)
Regards
Jose John
Re: Control Valve
05/22/2009 11:23 AM
If you want quick response on a linear valve, you can program (or adjust) dither on your controller, that'll keep your valve slightly oscilaling, thus giving faster response to a proportional position command.
Re: Control Valve
05/22/2009 11:33 AM
Spirax Sarco and Bela Liptak's control book have some pretty decent explanations. When you have sized your valve and contact valve manufacturers, they will come back with a characteristic and you can quiz them on their choice at that time.
Betomachine
South Africa - Member -
Good Answers: 12
Re: Control Valve
05/25/2009 2:32 AM
Hi there,
Download the fischer control valve handbook from www.emmerson.com
This will explain in a bit more detail what you are asking.
Regards,
Craig
Re: Control Valve
05/25/2009 2:56 AM
sorry sir, I could not able to open the link what you gave. it is asing login name and password, please give some other link to help me in this issue
Good Answers: 12
Re: Control Valve
05/25/2009 3:26 AM
Hi there,
www.documentation.emersonprocess.com/groups/public/documents/book/cvh99.pdf -
Regards,
Craig
Register to Reply 7 comments
Anonymous Poster (2); craigza (2); josej (1); PWSlack (1); ravindran_52k3 (1)
