Previous in Forum: Flow Reduction End Caps / Orifices   Next in Forum: Engineering Drawings
Piston Rods per Shift
05/22/2009 6:37 AM
how to calculate no of piston rods to be drilled in one shift?
given data,
dia-35mm
total length-605mm
drill size-dia 15mm
tap size-M18*1.5p
drill depth-50-52mm
shift time-8hours
manju
Re: calculation of piston rods per shift
05/22/2009 7:39 AM
  1. Find the "bottleneck" in the drilling operation.
  2. Measure the time taken for one part to pass through the bottleneck and another to reach the same place.
  3. Take the reciprocal.
  4. "Robert is your mother's brother".
Good Answers: 266
05/22/2009 7:45 AM
It is indeterminable with data provided. What material are the rods made of? What material and type of drill? Is the bit the type that drills and taps at the same time? Or is it separate operations to drill then to tap? Is both operations being preformed on the same piece of equipment? Equipment used? Coolant applied? Set up time?
Good Answers: 103
05/22/2009 9:36 PM
Don;t repeat the same question in multi forums,
It eats up the bandwidth.
The people normally scan through the forums for something interesting.
Register to Reply 3 comments
ozzb (1); PWSlack (1); sb (1)
