Previous in Forum: Reuse of Fasteners   Next in Forum: How to Calculate Lobe Pump Head
8 comments
Indonesia - Member - Member from Indonesia Engineering Fields - Mechanical Engineering - Mechanical Engineer Popular Science - Weaponology - Weapon Fan Safety - Hazmat - Safety First! Hobbies - Automotive Performance - Tuner Wannabe Hobbies - Target Shooting - I'm a good shooter
Hydrotest and PWHT Procedure for Propane Tank
05/26/2009 3:54 AM
Dear all..
Where can i find hydrotest and PWHT procedure for propane spherical tank?
Could you please explain me briefly about the hydrotest and PWHT procedure for that kind of vessel?
Please share your knowledge about these things
Thank you very much for your response.
Please give respectful & positive answer than insulting! Respect each other ok..
Re: Hydrotest & PWHT Procedure for Propane Tank
05/26/2009 4:19 AM
Open a dialogue immediately with the Engineer/Surveyor responsible for periodic inspection of the installation for the purposes of burst and fire indemnity insurance.
07/20/2009 8:01 AM
PLEASE SEND TO ME THE PROCEDURE
05/26/2009 4:39 AM
What is the standard for hydro and PWHT testing?
FYI, i used ASME VIII div 2 2007 for designing Propane tank.
Thanks all..
05/26/2009 4:44 AM
<...What is the standard for hydro and PWHT testing?...>
Where is the tank to be located?
05/26/2009 4:05 PM
Above ground.. Any idea Sir?
Thanks..
Good Answers: 51
05/26/2009 5:32 PM
You can find general guidance in ASME PCC-2 and this document:
http://www.hse.gov.uk/research/crr_pdf/1998/crr98168.pdf
And search this site (and others) for more general guidance, eg. ensure all air out of high points, .......
A little knowledge is a dangerous thing.
05/27/2009 11:28 AM
You need to state the country, Boss. National codes differ, you know.
Good moaning!
05/27/2009 4:45 PM
Check 49 CFR section 180. This is 2 times working pressure. Dry properly.
Register to Reply 8 comments
Anonymous Poster (2); Crabtree (1); Premium (2); PWSlack (2); XMech (1)
