Previous in Forum: Hydrotest and PWHT Procedure for Propane Tank   Next in Forum: Axial Flow Fans and Altitude
How to Calculate Lobe Pump Head
05/26/2009 8:02 AM
if we have flow rate of 500 lph for sauce & we have to pump it at height of 6 mtrs of two vertical sections, totl length of piping is 25-30 meters then how can we calculate the head of lobe pump
Re: how to calculate head of lobe pump
05/26/2009 8:25 AM
Please advise the following:
  • The density of the sauce
  • The viscosity of the sauce
  • The diameter of the pipe
  • The number and type of bends in the pipe
  • The smoothness of the pipe interior walls
05/26/2009 8:31 AM
density is 1.12 to 1.3 gm/cc
viscosity is 2600 to 3600 cps
mixing time is 25 to 35 min & hold time is 30 min. pls suggegest diameter depending upon flow rate
pipe is highly smooth EP
05/26/2009 9:28 AM
Wot no 'sauce jokes' ?.
How many sauce power will be required?
Are the pipes in mint condition?
Re: How to Calculate Lobe Pump Head
05/27/2009 2:05 AM
You just need to calculate the Pressure loss along the piping system, you have already the fluid data.
05/27/2009 3:50 AM
You need to refer to any hydraulic handbook to see how the prssure loss is calculated.
However, the equations refer to Newtonian liquids only.Sauce is thixotropic in nature and the laws of Newtonian liquids should not be applied directly.
I have calculated the pr drop based on the data you have submitted.
For a 1-1/2 " pipe dia the loss is 38 MWC or 3.8 bar,while for a 2" line it will be approx 17 MWC or 1.7 bar.
For accurate determination,you need to test run the pump in known straight length of pipe for a known flow rate.It is then possible to extrapolate the results for other dia pipes and flow rates.
You could use the following formula:
1) friction loss (m) = flow rate USPM x equivalent length of pipe(m) x viscosity in cP/1587 x d^4
where d is inches
conversion of 500 lph to USPRM is 2.2
2) To the result (1) add 6 metres of vertical run.
3)multiply the result in (20 by sp.gravity to obtain MWC equivalent
4) divide result (3) by 10 to get pressure drop in bar.
Chuck Cowlagi
05/27/2009 10:51 AM
Please read the USPM etc as US GPM for flow rates - otherwise the answer seems to be
good.
Anucool
Register to Reply 6 comments
Anonymous Poster (2); dvelho (1); megha (1); PWSlack (1); user-deleted-1105 (1)
You might be interested in: Rotary Lobe Pumps, Pump Repair Services
