Previous in Forum: Transformer Protection   Next in Forum: Higher Capacity Motor
TT Earthing System for UPS
05/27/2009 12:03 AM
Dear all hello,
Currently we use tow galaxy PW 120 KVA , UPS as parallel redundant , that we use the TT earthing system for upstream and down stream of UPS , and our load output disteribution panel is approxemitly in distance of 100 Meter , that all know in TT system one point of supply source is connected dieritly to earth ,and in all exposed and externous parts connected to separat earth electrod , if we connect one cable from first earth electrod with separate loud earth electrod , we can like this , and which one is better that the first option separately or connected to each ather just earthing system , plz advice me i am in problem.
Thanks & Regards
Mohammad fawad
Mohammad fawad
Re: TT earthing system for UPS
05/27/2009 3:13 AM
The method of earthing should not affect the performance of the UPS, as the earth conductor is only there to provide a safe path for the fault current until such time as the circuit protective device opens the circuit.
The performance of the UPS is determined by what happens on the phase conductor(s) and any neutral conductor only.
