Previous in Forum: Disconnecting Ammeters from Current Transformers   Next in Forum: UPS Ratings
Location: IM FROM MAGSAYSAY AVE., SINGCANG, BACOLOD CITY, PHILIPPINES,6100 ( AT THE SAME TIME IM AN AREA ENGINEER OF CENTRAL NEGROS ELECTRIC COOPERATIVE, INC., BACOLOD CITY PHILIPPINES.
Software for Capacitor Placement
05/29/2009 1:28 AM
Good day:
I just want to ask if somebody have a simple software on capactor placement on 13.8 kv distribution lines. Our utility have no capacitors on the 13.8 kv lines. I was hired last month as Enginering manager from abroad. We had a problem of low power factor, and power quality.I intend to purchase capacitors, however I need a program for proper placement for optimum result. Can anybody help me.Thanks and hope to hear from you soon.
REYNANTE T. BITAS, REE
Enginerring Manager
Re: capacitor placement Software
05/29/2009 5:21 AM
its is simple you should consult with any pannel making agency and tell them to install a 350 kvar capastor panel
05/30/2009 8:40 PM
dineshpandit180
How did you come up with a capacitor size of 350 kvar. You have no information to determine anything.
06/01/2009 9:48 PM
why can u use a group of synchronous capacitors?
05/29/2009 11:41 AM
What is the system PF? Are you trying to reduce load on the substation transformer or reduce line loading?
Good Answers: 61
Re: Software for Capacitor Placement
06/02/2009 12:24 PM
Most distribution modeling packages have the capability you want. I have worked with Synergee and Paladin DesignBase (for DesignBase, the capacitor placement module is a separate program which uses the system model database).
If your utility is using any type of modeling software, it may have a capacitor sizing & placement module in it, or one may be available for a reasonable cost. You must have feeder load information for the software to work. At minimum, power factor and kw is required for the feeders in question.
Anonymous Poster (1); dineshpandit80 (1); pwr2thepeople (1); wareagle (2)
