Previous in Forum: Thermal Expansion of Stainless Steel Foil   Next in Forum: Gas Absorption and Water
Physical and Chemical Properites for Alloys
05/29/2009 6:50 AM
Dear all,
Could any body help me out in finding((IN THE INTERNET(ANY WEBSITE ADDRESS)) the physical & chemical properties for alloy material.i have searched for it but i find lots of variation in many websites......
Good Answers: 53
Re: Finding physical properties
05/29/2009 6:57 AM
05/29/2009 6:58 AM
What is the composition of this alloy? What it its name?
06/01/2009 4:46 AM
This is zinc alloy(ZA-27).I have checked out in internet trough the help of google i and my friend itself find some other answer.Actually wat we got an idea is to use it for Pressure die ceasting for making a component.In that we need to know the shrinkage value of this material alone.
Good Answers: 58
Re Alloys
05/30/2009 8:15 AM
Without a specific question you won't find an authoritative answer. Sometimes there are variations in alloys, test equipment, and methods. ASM and the manufacturer of the alloy are generally reliable sources. Fabrication methods and heat treat history can result in substantial variations in mechanical, electrical, magnetic, and other properties.
Re: Re Alloys
06/01/2009 4:53 AM
Actually we are using Zinc alloy(ZA-27) for pressure die casting process we are trying it out for the first time in this alloy we need to know the actual shrinkage value after the die casting process for that i am looking for the solution me and my friend itself find different answers like 1.26% & 0.8% respectively.so it will be easy if we got the above said information..
PWSlack (1); rakesh_semwal (1); srinivasanramadas (2); welderman (1)
