Previous in Forum: Emergency lighting   Next in Forum: laser cutter for stones (granite)
low voltage switchgear in Hydro powerplant
05/30/2009 7:34 AM
why is it necessary to have full-proof interlocking to ensure that different supplies and transformers are never operated in parallel?
India
Re: low voltage switchgear in Hydro powerplant
05/30/2009 8:44 AM
DEAR<
simple reason that different supplies on in coming side are not in synch. mode, i.e. not in same phase. if paralleled, short circuits will occur in control section.
Exploring the Science of Electricity
05/30/2009 9:03 AM
yeah..dis one i know harry..i also replied this only to my boss..he said...no we may connect tahem in parallel for once...but it can create a disaster..
can u plz expalin me in detail ..i mean more elaborate ..
abt parapplel connection n all.
05/31/2009 12:42 AM
Dear Friend,
Can you tell us what type of hydropower, we are about to comment. Is it micro, mini, small and large (above 10MW) hydro power plant?
Full proofing interlock with LV (Swgr & Transfo) should be done and should never be in paralleled in above 10MW hydropower. But, in mini down to micro, transfo paralleling can be done in LV side only. Many rated combined power (MW) plant are splitted into equal turbine generator; for example if the calculated "Q" gives you a 3MW then you can split this to 3 equal turbine generator, which is 3x1000kW. Then, the output of these 3 TG can be synchronized or paralleled into one (1) 3500kVA transformer. Some small hydro power project are doing this except for the large one.
The station and feeder transformers, which is LV power is not required a full proof interlock. Only control and protection system is requied.
Eren
06/01/2009 2:53 AM
yeah ... m talking about mega hydroproject.. i.e. above 500 MW.
06/01/2009 4:30 AM
To avoid this:
Anonymous Poster (1); ereneduarte (1); harry potter (1); nesin (1); PWSlack (1)
You might be interested in: Hydro Turbines, Panelboards and Switchgear
