Previous in Forum: Power Supply for Controller   Next in Forum: O2 Probes and Failure Prediction
Instrument Cable Tray
06/03/2009 7:44 AM
Cable tray has classified as based on intrinsic safe & non intrinsic safe cable.
Further classified Digital & analog cable and pair & core cable.
Normally intrinsic & non intrinsic cable run in the same tray by barrier.
classified tray based on IS & Non-IS or classified like IS-Analog & IS Digital Pair & IS Digital Core.
Which is a best engineering part when we run the cable tray & tray calculation
Re: Instrument Cable Tray
06/03/2009 8:11 AM
In the UK it doesn't matter provided the requisite creepage and clearance distances are maintained for Ex 'i' circuits, which will be the case if using SWA cables on the IS circuits, and appropriate segregation of the instrument cables from the power cables.
Unless there is some standard in the Client's documentation that hasn't been shared here?
South Africa - Member -
Good Answers: 12
06/04/2009 1:31 AM
Hi there,
I think you should re-look at your countries regulations regarding intrinsic safety.
First of all download the following:
www.crouse-hinds.com/CrouseHinds/resources/
intrinsically_safe/insafe.cfm
Intrinsically safe circuits may be wired in the same manner as
comparable circuits installed for unclassified locations with two
exceptions summarized as separation and identification. These
wiring practices are simple and clear; however, they often are
overlooked and are the source of potential problems.
The intrinsically safe conductors must be separated from all
other wiring by placing them in separate conduits or by a
separation of 2 inches of air space. Within an enclosure the
conductors can be separated by a grounded metal or insulated
partition.
Personally, I prefere to seperate IS and non-IS signals. In most cases, I end up with <1% of the total signals being non-IS. In cases like this - I make every signal IS. This prevents confusion arising as to what is IS and what is not. It also eliminates the possibility of the local maintenace crew connecting a IS signal to a non IS input.
Regards,
Craig
06/11/2009 8:34 AM
As referenced in the information by Craigza the only other add to your comment is that when a signal is IS it does not matter if it is analog in or out or digital in or out. they can be run together in the same tray without separation of the IS cabling. Only in cases where there is analog non incentive and discrete cabling (120 vac and Higher) require separation in most facilities. This to eliminate induction from the higher voltages to the analog and low voltage signals.
craigza (1); PWSlack (1); ral412 (1)
