Dear all,
I am doing my master thesis in the characterization of a solid-state P-N gamma detector.
I understand that after the pre-amplification, the signal can be shaped to have a better electrical signal to measure in the MCA or SCA.
However once the signal is digitized after the pre-amplifer as in some of the current detectors, why do you need to process the signal through a digital shaping amplifier? From my point of view the information is already in the amplitute of the signal, therefore there is no need to make shaping processing as in the analogue case.
If the sampling speed is good enough (nyquist theorem) then the amplitute of the pulse can be easily extracted by looking the samples. If it is not, then the digital shaping amplifier does not work as well.
Can anyone tell me why the shaping amplifier?
Nil García
