C writes:
I need to find something that measures air flow though foam. The foam is about 18mm-30mm wide and 3mm-4.5mm thick, with varying lengths. I want to compare the flow rate between foam of slightly different densities. This is just a way we can test foam from suppliers off-line. Any ideas?
