Previous in Forum: How to Calculate Dynamic Average Speed   Next in Forum: Generators and Power Plants
Venturi Injectors and Suction Calculations
06/05/2009 7:47 AM
Dear Sir,
we are going to use a venturi injector to inject ozone gas into water.How to calculate the suction of the venturi say for example the pipe diameter of upstream venturi is 7.4cm,Diameter of ventury neck is 3.05cm,fluid density is 1kg/m3.
Senthil
Re: ventury suction formulae
06/05/2009 8:27 AM
The maximum suction will be determined by the temperature of the water. Look up its boiling pressure in Steam Tables.
Good Answers: 101
Re: Venturi Injectors and Suction Calculations
06/05/2009 10:42 AM
Check the venturi curve. There should be a formula on the curve or the catalog that will enable you to work out the details as well.
