Previous in Forum: Maximum Current from Single-Phase Power Supply   Next in Forum: Transformers: Liquid Dielectric or Not?
Changing the Voltage for an Air Compressor
06/05/2009 9:17 AM
I have I have air compressor it s 380 volt how can I change it to 230 volt ( it s 3 phs)
Re: Changing the Voltage for an Air Compressor
06/05/2009 9:21 AM
By getting in touch with the original equipment manufacturer, and following their recommendations.
Good Answers: 137
06/05/2009 10:14 AM
Assuming your 230v supply is 3-phase, 230v phase-phase, if the motor is 380v Y, 220v Δ, just connect in Δ. (220 and 230 are near enough)
If it's 380v Δ, 660v Y, you need to change the motor.
Cheers..........Codey
06/05/2009 11:30 AM
That motor seems to be a 380V 50Hz. 3Ph. and should be ready to run on 440V 60Hz. 3Ph. with no change, but for your supply which is 230V you would need to do these connections in your motor IF your motor has 9 leads:
For a Y connection: Conect 4 & 5 & 6 together and isolate; then connect 1 & 7 to phase 1. Connect 2 & 8 to phase 2. And connect 3 & 9 to phase 3.
For a Delta connection: Connect 1 & 6 & 7 to phase 1, connect 2 & 4 & 8 to phase 2 and connect 3 & 5 & 9 to phase 3.
If your motor has only 3 leads, then it is not dual voltage and you've gotta change it.
Yahlasit
06/06/2009 3:46 AM
Buy a single phase motor of the same power....or bigger.....sell the old motor to finance the new/second hand one....
Register to Reply 4 comments
Andy Germany (1); Anonymous Poster (1); Codemaster (1); PWSlack (1)
