Previous in Forum: Black Box Flight Data Recorder   Next in Forum: Control Valves and Line Size
when will we tuned the zero and span of i/p converter?
06/07/2009 2:54 AM
when will we tuned the zero and span of i/p converter? and what will be the condition of valve or i/p ,when will we tuned the zero and span?
Good Answers: 54
Re: when will we tuned the zero and span of i/p converter?
06/07/2009 5:44 AM
There are two instances of when to calibrate a device:
  • When the calibration schedule says that it's due to calibration (you do have a schedule, right?)
  • If you have reason to doubt that the unit is out of calibration
After you have calibrated the device, assuming you did it properly and the device is not defective, the unit should perform properly.
regards,
Vulcan
Good Answers: 54
06/08/2009 12:00 AM
My bad...erratum
  • When the calibration schedule says that it's due to calibration (you do have a schedule, right?) ... When the calibration schedule says that it's due for calibration (you do have a schedule, right?)
  • If you have reason to doubt that the unit is out of calibration ... If you have reason to believe that the unit is out of calibration There's no grammar check button for the editor. regards, Vulcan
06/08/2009 7:55 AM
suppose some problem came in control valve at time of operation . i asked 4 maintence .
Good Answers: 54
06/08/2009 7:20 PM
As I said, if you have reason to believe that the converter is defective (at anytime), you need to have it calibrated. If some problem came up during operation, then you have reason to believe that it is out of calibration.
I sense that this is going nowhere. Please provide complete information about your problem so that we can give complete answers. Don't be shy about giving details.
regards,
Vulcan
06/07/2009 6:56 AM
HI
Its necessary to tune the zero and i/p converter when there is defect in the control valve.
Also its necessary when the control valve is under maintenance.
Usually Control valve and i/p converter are calibrated based on the process disturbances.
Regards,
Zaki
Radicon Gulf Consult
KSA.
06/08/2009 7:55 AM
06/08/2009 9:42 AM
By "tune" I assume you mean calibrate (I know, ass/u/me ). The I/P should be calibrated prior to the calibration of the valve positioner. The calibration of the I/P may be checked periodically as your PM schedule dictates or as the valve performance comes into question.
Register to Reply 7 comments
Anonymous Poster (3); dubl_xl (1); Vulcan (3)
