Previous in Forum: Plant Assessment Checklist   Next in Forum: Life Cycle Assessment (LCA)
Calculating Forging Press Tonnage
11/30/2006 4:09 AM
Dear Sirs I am working in forging area and i want to know how we can calculate the tonnage of power press depending on our component. Max. size of our brass ring component is 84mm and max. thickness is 14mm.
Re: Calculating Forging Press Tonnage
12/01/2006 10:16 AM
Having been exposed to hot brass stamping, and referring to the ASM handbook Volume 4 'forging and forming, it would be seen that the thumb rule to select the tonnage of press for hot brass forging for simple components (as yours) is 40 tonnes per square inch of projected area of the forging. This value is revised upwards in the event of thicker and cored forgings. In your case, the value of 40 tonnes per square inch of projected area should work.
Lalit Thakkar
12/03/2006 3:15 AM
Dear Sir,
We kindly inform you that we are India based SEO firm.
We have team of five engineers for SEO job.
We kindly request you to please let us know any of your requirement in this regards.
Thanks & Regards,
Harish Doshi
