The clause no E4.1 of API 650 FOR TANKS, has the following words"..or for unanchored tanks, the weight of the portion of the contents adjascent to the shell"
What is the maening? What is the volume of the tank content to be considered? Pl clarify
The further calculation formula does not talk about the weight of the content. The weight of the content should be added to the weight of the tank to match with the over turning moment.
wL = maximum weight of the tank contents that may be used to resist the shell overturning moment, in lbf/ft of shell circumference.
(the units don't work out because the equation is empirical based)
(and this may be significant if you are designing a new tank - you seem to be using an older edition of API 650 - 10th or earlier, because the latest 11th edition has this clause in E6.2.1.1 - API 650 is a VERY dynamic code)
A little knowledge is a dangerous thing.
