Previous in Forum: Fuses and Potential Transformers   Next in Forum: The Myth of Ground
Water Cooled Motors vs. Forced Water Cooled Motors
06/08/2009 9:03 AM
Can any one please explain the difference between water cooled motors and force water cooled motors.Normally I have seen water cooled machines do have a pump to force the water through the heat exchanger.recently I have come across this term foce water cooled.I am unable to comprehend what it is and in what way it differs from normal water cooled machines.
Re: Water Cooled Motors vs. Forced Water Cooled Motors
06/08/2009 3:54 PM
It could be a simple marketing or technical miscommunication (ie- both mean the same thing), or the forced water cooling motor could have a separate system for pushing the water thru the heat exchanger.
What's the application?
06/09/2009 1:48 AM
Thanks for the response.It is Boiler feed pump application 4500KW4Pole .
06/12/2009 7:30 AM
4500kW is a 'king big motor!
Should that be 4500W?
06/12/2009 8:38 AM
It is 4500KW only.These are small when compared higher ratings we have handled like 8MW 19MW etc.The question still remians unanswered
Register to Reply 4 comments
Anonymous Poster (1); jack of all trades (1); nesubra (1); PWSlack (1)
You might be interested in: DC Motors, Stepper Motors, AC Motors
