Previous in Forum: Pitot Tube Calibration Services   Next in Forum: A/C Load Calculation
Air Flow Volume into Jet Engines
06/09/2009 11:08 PM
air flow volume into jet engines? Is there a standard measure? Is there a comparative volume for air forced by a propellor?
Pathfinder Tags: air flow jet engines
Re: Air flow volume into jet engines.
06/10/2009 3:23 AM
OK. There must be a relationship between the inlet area of the duct and the velocity of the aircraft....
Does that help?
06/10/2009 12:12 PM
Tjhank you for response. Yes. - I am looking for volume of air processed by jet engines, and controlling flow of such. I am looking at technical data too, but am looking for some gneral principles.
Good Answers: 62
06/11/2009 6:08 PM
Trying to help, but not sure where you are going...
Volume is measured, but not controlled.
Flow is ~roughly~ controlled by fuel.
Try looking up:
N1, N2 Pressure ratio
EPR
TGT
That will allow us to get to common terms.
Re: Air Flow Volume into Jet Engines
06/11/2009 8:41 PM
Thanks. IU will re-phrase the question, and re-post.
Register to Reply 4 comments
edignan (1); nobler (2); PWSlack (1)
