Previous in Forum: Boil Drum Instrumentation   Next in Forum: PID for PLC
Pipe and Instrumentation Diagram (P&ID)
06/10/2009 7:15 AM
Hellow colleague,
I came across these letters on an P&ID: Pipe designed in according to WDFL-0312. And also on another P&ID I saw thus: KAQ; GaY; KAH; D1, A1; E1 and CIR
If someone have an idea of what these letters mean please help explain them for me.
thank you.
Re: Pipe and Instrumentation Diagram (P&ID)
06/10/2009 9:59 AM
There should be a drawing interpreting the symbols as part of the drawing pack, just to cater for occasions like the one posted.
"Ban abbreviations ASAP!"
South Africa - Member -
Good Answers: 12
06/11/2009 1:21 AM
Hi there,
As PW said - there should be a "Lead sheet" for your P&ID's. This is usually the sheet after the index.
Usually (not all cases) the line number is made up like such.
xx-yyy-zzz-aa-bb
Where:
xx - process medium abbreviation e.g. PW - Process water
yyy - Plant area number e.g. 613
zzz - Unique pipe number
aa - Line size (might be nominal bore)
bb - Pipe material e.g. MS - Mild steel.
Put it all toegther - PW-613-001-40-MS
Regards,
Craig
06/12/2009 5:06 AM
I thank you gays for your comments on the P&ID issue for futher clearification there was number thus: PL-C1R-1003; PL-A1-1104. I belive this will throw more light on the question.
Thank you
Good Answers: 18
08/02/2009 1:05 AM
Some of those are instrumentation symbols, others are likely to be something else.
Have a look at the following for a good explanation:
http://lamspeople.epfl.ch/kirrmann/Slides/HowToReadP&ID.htm
In brief:
KAQ - time-alarm-integration (integration over time, in this case)
Means 'something integrated (integral of something) over time time is too long or short', adding an H to the end would mean that the integrated value is too high (past an alarm point), adding L means that it's too low.
KAH - time-alarm-high
Means 'time measured is too long', something has taken too much time.
CIR - (user's choice)-indicator-recorder
'C' is often used to mean 'conductivity'. Whatever the C means here, the instruments measures cariable-type C, indicates it (it has a display mounted on it, or if it's on an operator screen, the measured value is displayed there), and the measured value is recorded in a data historian.
Most likely, this 'instrument' is a recording indicator on an operator screen. The instrument that measures C would then be CT (C-transmitter) or CIT (C-indicator-transmitter).
Cheers!
MZ
Do unto others. Then run.
Anonymous Poster (1); craigza (1); DreadZontar (1); PWSlack (1)
