Previous in Forum: Weight of a BBQ Pit   Next in Forum: What's the Difference Between Marketing and Sales ?
Fuel Cells
06/10/2009 7:35 PM
On the Opollo 13 space mission, a spark caused an explosion in one of the onboard oxygen tanks. They had to shut the command module down to conserve power for re-entry. How did these fuel cells work and what role did the lack of oxygen play in their depletion?
Best Regards, Respectfully, ToolmakerG
Re: Fuel Cells
06/10/2009 8:02 PM
Re: Fuel Cells
06/10/2009 8:27 PM
Thanks. I have always been fascinated with NASA. This will make good reading.
Re: Fuel Cells
06/11/2009 3:33 AM
The world held its breath during the Apollo 13 incident, and the relief when the three astronauts survived was shared across many nations. At this time, NASA missions were broadcast live around the world to much public interest, and the possibility of losing three astonauts in difficult circumstances caused much anguish. Their survival owes much to the concept of teamwork.
There is a film called "Apollo 13", featuring the American actor Tom Hanks in the lead role. It is well worth watching, and gives a very credible illustration of the issues at play during this difficult mission.
Re: Fuel Cells
06/11/2009 10:19 AM
Thanks, Yes I watch the Apollo 13 movie regularly. That is where my question was generated. I now have a better understanding of the need for the oxygen in the fuel cells. I also enjoy watching the efforts toward a Mars expedition in channels like the science channel.
United States - Member - Member Hobbies - DIY Welding - New Member
Good Answers: 50
Re: Fuel Cells
06/11/2009 10:53 PM
I would suggest reading the book "Apollo 13", originally titled "Lost Moon", co-written by mission commander Jim Lovell.
Not only is it a riveting blow by blow description of the events, but a background look at an astronaut's career AND some forensic engineering analysis at the end of the text.
Shows how simple and small things (an engineering/design oversight, a small incident, a bad decision and coincidence) can lead to an major accident (as it seems with the recent Air France tragedy).
Speak softly and carry a big stick.
Re: Fuel Cells
06/11/2009 11:00 PM
Hi ToolmakerG, all NASA projects and historic information can be found at:
http://www.nasa.gov
regards
Re: Fuel Cells
06/12/2009 12:12 PM
No direct answers seen; in those fuel cells, since nothing that was not brought along would be available in space, they brought both hydrogen and oxygen. These get combined in the appropriate ratio (2 Hydrogen to 1 Oxygen); the byproduct is water, which could then be recycled and used. This reaction happens at a membrane made typically of some fibrous material imbedded with a catalyst such as platinum, which aids the chemical reaction. Since each cell only generates about 1.2VDC, they have to be stacked in series to create the higher voltage needed to feed a power inverter which then powers whatever is onboard, and also charges batteries with the spare power.
When the oxygen cylinder blew up due to an uninsulated/burned insulation wire, the oxygen in that tank blew into space, and of course, deactivated that fuel cell and may have done other damage as well. At that point, they were short on power and had to reduce power as much as possible, which included heat for the manned areas of the capsules. That left them pretty cold and dark for most of the flight, but did enable them to get home.
Register to Reply 7 comments
Anonymous Poster (2); jack of all trades (1); PWSlack (1); standarded (1); ToolmakerG (1); whatthef (1)
