Previous in Forum: Electrical Heating   Next in Forum: Problem Process Cooling Water System
8 comments
difference between SA106 GR B and SA 516 GR 70N
06/15/2009 7:56 AM
PLEASE HELP IN FINDING THE DEFFIERENCE BETWEEN difference between SA106 GR B and SA 516 GR 70N IN THE WAY OF STANDING HIGH TEMPERATURE
WE WILL USE THE SUITABLE MATERIAL IN FIRE TUBE IN HEATER TREATER FOR CRUDE OIL AT WORKING TEMPERATURE BETWEEN 450 F TO 500 F
REGARDS
Good Answers: 103
Re: difference between SA106 GR B and SA 516 GR 70N
06/15/2009 9:03 AM
One is a Seamless Tube and another plate (unless I am mistaken).
Both are used in high temperature services (heat exchangers of thermal power plants at much higher temperatures)
However for hot oil services you must check up the relevant code. You may check the ASME Sec II
06/15/2009 10:44 AM
Please confirm that you are looking for the material specifically for the tube, and not another component such as the shell, channel, etc ......
Also please confirm the metal temperature of the tube.
06/15/2009 10:59 PM
yes it is for the tube
the tube material is between 450 F to 500 F
Good Answers: 51
06/15/2009 11:54 PM
You should use an actual "tube" product form, for example, in this type of relatively low temperature:
SA 192 - Standard Specification for Seamless Carbon Steel Boiler Tubes for High-Pressure Service
Or if you were going to a higher temperature/superheated:
SA 209 - Standard Specification for Seamless Carbon-Molybdenum Alloy-Steel Boiler and Superheater Tubes
The biggest reason for going with a 'tube' form is the tighter tolerances on outside diameter and ovality for attachment into machined/reamed tubesheets.
You can find the relevant allowable stresses in ASME Section II - Part D
Note that SA-516-70 is a 'plate' form and would unnecessarily require rolling and welding to make into a tube form. And SA-106-B is a 'pipe' form with looser tolerances.
A little knowledge is a dangerous thing.
06/16/2009 12:04 AM
what about the temperature
which is standing temperature more
Good Answers: 51
06/16/2009 12:15 AM
You need not worry about any of those relevant product forms for your stated temperature (500F), for example
SA-192:
  • Maximum allowable temperature = 1000 F (Sec I & VIII)
  • Creep effects at temperatures greater than 750 F
  • Not recommended for extended service above 800 F due to graphitization
and I suggest looking @ ASME Sec II-D for further examples/numbers/allowable stresses.
Good Answers: 51
06/16/2009 2:57 AM
My apologies - I had in my mind water boilers, but you mentioned simply "heater". And perhaps you are looking at API 12K, where they specifically mention coils of A106-B without tubesheets, so in this case you would definitely pick a tubular (pipe) product because you wouldn't want to roll plate (516-70)
Good Answers: 103
06/17/2009 9:43 AM
Here the queation is not what can withstand more temperature.
case 1 - seamless tube
case-2- plate rolled and then welded to form the tubes.
The codes will not allow you the second case even if the parent metal has a higher temperature withstanding capacity.
Register to Reply 8 comments
Anonymous Poster (1); mostafaalkholy (2); sb (2); XMech (3)
