Previous in Forum: Earthing   Next in Forum: Charging Sets vs. Charging Generators
NEED REPAIR INVERTER MITSUBISHI
06/15/2009 3:56 PM
HELLO EVERY ONE, I NEED TO FIND OUT SOME BODY WHICH HAVE SPARE PARTS TO FIX A DRIVE MITSUBISHI FR-A540-15K-NA. IT LOOKS LIKE THE CPU IS DAMAGED. SEND ME YOUR COMMENTS.
Good Answers: 804
Re: NEED REPAIR INVERTER MITSUBISHI
06/15/2009 7:20 PM
That drive is probably over 7 years old now, meaning that there are likely to be other components ready to go on it now (mainly the capacitors). You might consider buying a new drive. There are plenty of companies that will repair it for you, but the cost will likely be right up there with the cost of a new drive.
06/16/2009 12:15 AM
It's no point to send it for repair. The repair cost will be almost the same cost as a new set of speed drives. Just buy a new speed drive and replace it. Of course , you have to check and compare the new speed drive with the old speed drive. Some of the termination may not be the same number. You may need to rewiring the new speed drives and the parameter setting.
06/16/2009 3:08 AM
  1. Turn off Caps Lock
  2. Replace the unit.
JRaef (1); PWSlack (1); Simon Wan (1)
You might be interested in: CPU Cards and Modules, CPU Chips, CPU Fans and Coolers
