Previous in Forum: Plate Material and Mill Undertolerance   Next in Forum: Wanted: Venturi Gas Injector
8 comments
Gasket Stress
06/16/2009 5:52 AM
If a gasket has an efective min sealing stress of 5000 psi what does this equal in NM?
Good Answers: 103
Re: Gasket stress
06/16/2009 6:11 AM
PSI (pound / square inch) pressure, stress, strength) is not the same as N-m (energy, work done) ML-1T-2 vs ML2T-2
one is force/ unit area the other is force x distance
If you want it is in N/M2.
You can get any number of online calculators to do this like this one
and it has a lot of others attached too.
Re: Gasket stress
06/16/2009 6:16 AM
Newton-metres might be the torque on the bolts needed to secure the gasket, perhaps?
Good Answers: 103
Re: Gasket stress
06/16/2009 6:39 AM
You must be right. How can I miss that .
OK Edgar, there are somewhere between 10-100 threads on CR4 on this subject- check any of them. (any way most have to be and are repetitive)
Re: Gasket stress
06/16/2009 6:47 AM
The original poster omitted the definition of the abbreviation 'NM'. It was a guess.
CR4 should ban the use of abbreviations ASAP.
Re: Gasket stress
06/16/2009 7:13 PM
For those who are used with SI, the post is also confused about the use of capital letters. To clarify to the poster: N is for Newton; m is for meter; psi for pounds-per-square-inch Nm would be for torque in SI. NM does not exist.
Humm... suspicious you are...
Re: Gasket stress
06/17/2009 6:03 AM
Such is the terrible assumption that one must make with abbreviations. Ban abbreviations ASAP!
Engineering Fields - Piping Design Engineering - New Member Engineering Fields - Mechanical Engineering - New Member
Good Answers: 27
Re: Gasket stress
06/16/2009 7:42 AM
Hello Guest,
It's clear what you seek but, we can't help without further details:
  • What is the size of the bolts being used?
  • What is the grade/material of the bolts being used?
  • What K Factor do you think may apply?
Once you have these data, torque can be calculated in Imperial units (ft-lb) and then be converted into the SI units which you want (N-M)
With regards to the above K Factor: If the value which you choose is not the same as the actual friction factor, your calculated torque will not develop the desired gasket stress.
Here's a link to a page with some simple bolt load calculation spreadsheets that might give you a good start.
Best regards, HeviiGuy
Good Answers: 27
Re: Gasket stress
06/16/2009 7:46 AM
... the above information will suffice if the joint has already been designed and you're simply looking for the torquing value for a known flange size/rating and operating conditions. If you're starting from scratch, there will be much more work involved!
bhrescobar (1); BoltIntegrity (2); PWSlack (3); sb (2)
You might be interested in: Sealing Machines, Gaskets and Gasketing
