Previous in Forum: 2002 Mazda 323 - Strange Hissing Noise   Next in Forum: Hydroxy Generators
1991 Acura Integra RX - Two Problems
06/16/2009 5:34 PM
I have 2 problems.
1. When stopped the car idles.
2. When I accelerate the car acts like it wants to cut off and then it accelerates.
What might be causing both of these problems?
User-tagged by 1 user
Re: 91 Acura Integra RX
06/16/2009 11:24 PM
Hello Guest (whoever you are),
1) The definition of a car idling is when it is stopped with your foot off the accelerator; do you mean it idles even when you turn it off?
2) Check the fuel filter and replace if necessary.
Mike
Good Answers: 123
06/16/2009 11:54 PM
1. If your car did not idle it would be racing, or it would stall. I think idling sounds like a good thing.
2. Check fuel pressure, and high voltage ignition system. ( coil, rotor, cap, plug wires, and spark plugs.)
Good luck.
Bob
Re: 1991 Acura Integra RX - Two Problems
06/19/2009 1:51 PM
I am uncertain what you mean about problem #1. The car should idle when stopped. Do you mean it will not idle , i.e. the engine dies or the idle is not smooth. i.e. it misses?
Question # 2 appears to be a surge. Check the throttle position sensor.
Dennis Waller
bob c (1); DennisWaller (1); Mikerho (1)
