Previous in Forum: Air conditioning your offices and homes using solar or gas fired systems   Next in Forum: airconditioning
loose power in diesel engine
06/18/2009 11:49 PM
if some body want run a diesel engine wit gas , I think its too wrong becaue its same to run a diesel engine wit gasoline, get up body.you can destryoed the engine,maybe
you can kill you self or some body.
Joffre Benavides.
Re: loose power in diesel engine
06/19/2009 12:04 AM
Yes, trying to run a diesel engine on gasoline is counterproductive and is never recommended for obvious reasons.
06/19/2009 3:43 AM
Good Answers: 18
06/19/2009 8:54 AM
I like the way you express yourself! GA!
06/19/2009 8:32 PM
Diesel engine not go BOOM on Gas. Gas not blow heads off diesel engine. Old Yankee trick is to add Gas to Diesel to stop gelling (not yelling) in many cold winter day. Our Government has made numerous "multi-fuel" engines for the military with great success. (Most of the older engines were mainly diesel.)
Have I put Gas in Diesel before? Yes, as long as there's enough diesel it will run but like a sick dog. Gas is not good for diesel pumps and injectors!
I am sorry, I couldn't help myself.
CaptMike
06/20/2009 8:49 PM
Are you confusing natural gas (methane) or propane gas with gasoline? It's comparing apples and oranges. Diesel engines run just fine on the former, if properly set up.
As to the later post, some early spark-ignition engines were started on gasoline, then when the manifolds were hot enough, they were switched to fuel oil (heated by the exhaust).
ASCII silly question, get a stupid ANSI.
Help
09/03/2010 10:29 AM
Dear all, I have a ford 450 turbo diesel, and has a diferent noise, I need check if you can help me for send me ans answers of why the noise is diferent.
Regards,
Bryan.
Anonymous Poster (1); Bill (1); CaptMike (1); jack of all trades (1); Mark Stockman (1); PWSlack (1)
