Previous in Forum: Solar Shields and Ground Temperature   Next in Forum: knurled check nut
Looking for an Electrovalve
06/19/2009 9:07 AM
Hi,
I am looking for a DC water electrovalve to put in a normal water tap at home but I need it to be off/on. What I mean is a selenoid that will transition from off->on when a control pulse is applied and then stays on without any voltage applied. To turn it on->off again, another pulse need to be applied.
Does anyone know any suppliers of these type of selenoids ? I couldn't find anything.
Thanks/Brgds
João
Pathfinder Tags: electrovalve selenoid Water
Re: Looking for a water electrovalve
06/19/2009 11:58 AM
A latching solenoid valve should suit you.
E.G.
http://www.giplindia.com/latching-solenoid-valve.htm
Hobbies - Musician - New Member Engineering Fields - Manufacturing Engineering - New Member
06/19/2009 12:24 PM
You need a latching solenoid water valve.
Typing ' latching solenoid water valve ' into a google search returned 17800 hits.
Many are low voltage/battery operated. Depending on where you are located, you should be able to find what you are looking for from a local plumbing supply distributor.
Then you just need to decide how you want to control the valve. Or, there are many manufacturers and distributors of faucet packages that already do what you want. Not cheap however.
Happy hunting.
Courage is not the absence of fear, but the inner resolve to rise above it....or the inane lapse in judgement brought on by copious imbibitions....Egre Flagrus
Re: Looking for an Electrovalve
06/22/2009 9:41 AM
Good morning, check with your local kitchen appliance repair store, a typical dishwasher has a normally closed electrically operated valve in the bottom. Don't know if AC or DC, hope this helps.
The beach is a place were a man can feel, He's the only soul in the world that's real. - Pete Townshend... Who?
06/22/2009 10:30 AM
thanks to all.
J
Register to Reply 4 comments
jcasqueiro (1); Onthebeach (1); snygolfgs (1); woodygb (1)
