Previous in Forum: Taper Angle   Next in Forum: Warm Jeep Won't Idle Well
13 comments
Mazda Protege 2003 - Squeaky Steering Wheel
06/22/2009 6:07 AM
I have a Squeaky sound every time I turn the steering wheel (left or right). I've had it before, but it was the dealer that fixed it and they told me that, the sound was coming from a rubber seal that needs to be lubricated. I wanna fix it, but I don't know where the seal is located, can anybody help me? Thanks in advance.....
Pathfinder Tags: 2003 mazda protege steering wheel
Re: Mazda Protege 2003 Steering Wheel
06/22/2009 10:29 AM
I had few months of experience in steering company and I assume that you are using hydraulic steering systems in mazda. In hydraulic steering there are many seals are used. I presume that you had that sound during left and right turn and mostly this sound comes in the piston seal which is moving inside the hydraulic cylinder. the main cause of the sound is due to the metal contamination present inside the hydraulic cylinder.
Do you have the warranty for the steering system? it is better to go for that because steering system is bit complicated with lot of tiny parts? do not dismantle it and make the manual work in your steering system. It is safety components and needs lot of setting even after you change the seal which cant be done even by service professional in your local place. better choose to bye the new steering system and fix it in mazda...eventhough it is costly it is best solution I could advise.
otherwise just give a try to change the lubricant of your steering system. it may remove your metal contamination which inside the cylinder..cheers
Good Answers: 97
06/23/2009 2:12 AM
jeev4,
Though a consideration your point is not very sharp and the least or shall I say waay out in left field. What your are describing is termed cavitation but not due to metal contamination...
Good Answers: 97
Re: Mazda Protege 2003 - Squeaky Steering Wheel
06/23/2009 2:14 AM
CaceresNB,
Hello please describe the motion which causes the squeal.
Is it when turning the wheel and holding it at full turn, against the stop?
06/23/2009 5:55 AM
just by turning it
06/23/2009 2:18 PM
Does it squeak only when the motor is running?
Does the temperature make a difference?
Good Answers: 97
06/23/2009 3:01 PM
You'll need a repair manual for your vehicle, all your answers are in it, all the necessary tools and the exact method of disassembly an will have exhausting explanation also.
06/23/2009 4:52 PM
Well I've notice that, when the temperature drops at 59 degrees I don't hear it anymore but if it get's above 68 it starts. I dont think the temperature of the motor has to anything with it.
06/24/2009 1:38 AM
If what you say is true, there is a possibility that it is only the plastic covers around the steering wheel that are causing the squeak. It has happened to me in this way. I took them off for a few days and the problem was solved at all temperatures. carefull examination showed a small area of contact, a light filing and the problem was fixed.
Or you may be lucky even after inserting all screws, but not tightening, move parts away from each other as you tighten up.....
Good Answers: 97
06/24/2009 12:00 PM
A casual application of talc keeps the squeaks at bay
06/24/2009 3:10 PM
HOW DARE YOU Sir?
Are you insinuating that my Arse squeaks when I walk if I don't use the Talc????
06/25/2009 6:31 AM
nice one
Good Answers: 97
06/25/2009 8:51 AM
Are you commenting to the right thread
see how you roll
Good Answers: 123
06/30/2009 12:02 PM
I was plagued with an annoying squeak from my wife's steering wheel. I was convinced it was the horn contact. I was wrong. It was a rubber sleeve that seals the steering column to the firewall. Try spraying anything that moves against a non-moving part with WD40, or other light oil. Once the noisy area has been found, work with dry lubes. Moly spray stinks, but works well as do teflon, graphite and dry silicone. Good luck.
Bob
Register to Reply 13 comments
Andy Germany (3); bob c (1); bwire (5); CaceresNB (3); jeev4 (1)
You might be interested in: Seal Repair Services, Form, Fill and Seal Machines
