Previous in Forum: Mazda Protege 2003 - Squeaky Steering Wheel   Next in Forum: Engine Oil and Low Viscosity
17 comments
Good Answers: 101
Warm Jeep Won't Idle Well
06/22/2009 4:08 PM
Normally I'm quite competent when troubleshooting auto issues, but this one has me baffled.
Couple weeks ago, I got caught in a instant thunderstorm that dumped quite a bit of water on me. Of course, I had my top removed, and ended up with a downright soaking wet jeep. I put it under cover to dry out over the weekend. When I went to start it up, It acted like it had a dead battery. I got a jump, and it fired right up, but would not idle at all... until the jumper cables were removed... then It idled fine on it's own... for a week or so.
which brings me to the present... The last couple of days, when I fire it up in the morning, It idles fine.... until its warmed up. once it has reached close to operating temp it will no longer idle when the vehicle is sitting still. Up to this point its not that mysterious...
This is the point that gets me scratching my head: The jeep idles great as long as my tires are turning. For example: I can be doing 60Mph, disengage the drive train, put the trans in neutral (its a 5 speed) and coast. While its physicly moving it idles as if there were nothing wrong, so it will idle the whole time from 60mph coasting to a stop. As soon as the vehicle physicly stops moving, it dies.
I dont know of any other sensors besides the one hooked to my spedometer which will read vehicle speed. So why will it idle when moving, but die the second the tires stop spinning? I'm sure the problem can be traced back to some electronic sensor that was exposed to the water... but what? is the spedo sensor used by the computer to help idle? how would they be connected...?
Any insight is greatly appreciated.
-Russ
Hobbies - Car Customizing - New Member
Good Answers: 11
Re: Warm Jeep Won't Idle Well
06/22/2009 11:01 PM
a little help?
what year?engine?fuel injected/carbureted?computer?
Good Answers: 101
06/23/2009 11:12 AM
Awww Geeze... Can't believe i left out the important specs.
Its a 2000 Jeep Wrangler Sport, with the 4.0.
Hobbies - CNC - New Member Engineering Fields - Mechanical Engineering - New Member
06/22/2009 11:25 PM
Dirty- loose battery cables...... could be that the rain was the straw that broke the camels back.The jumper cables being removed was a clue that they were loose and the movement of them on the battery posts caused the symptoms you descibe. Any trouble codes?(check engine lite) if not probably cables..... hope I helped.....
the sarcsm is free.......
Good Answers: 101
06/23/2009 11:13 AM
no codes, no check engine light.
06/23/2009 12:46 AM
Most often, the rough idle is caused by a vacuum leak. Could the sudden onslaught and torrential down pour of water and thus the water spashing under the vehicle have blown off a vacuum line and when you press the brakes the idle becomes rough?
If you have the famous Quadratrac vacuum operated shift transfer case, chances are, a vacuum line mounted anywhere along the line (inlcuding the interior switch) was knocked off.
Good Luck!
JL Mealer
Mealer Companies LLC
http://mealercompanies.com
Good Answers: 101
06/23/2009 11:14 AM
The jeep must have finally dried out to the point that whatever was causing the issue, has resolved itself...
06/23/2009 5:26 AM
I recall from my college days a friend with a 70's vintage Toyota land cruiser- part of the emissions control scheme was that the engine seemed to be on a faster idle stop while the vehicle was moving, and the engine would go to slow idle once stopped. It had a stick shift. To drive it gave me the idea that it was never intended to "engine brake" at very low speeds. I didn't understand the emissions aspect, nor how speed was sensed, but I wonder if this is somehow related to your problem.
Good luck, sounds like you'll have accomplished something once you solve this one.
Good Answers: 73
06/23/2009 8:34 AM
I have a Jeep Cherokee that had the same problems. The problem was due to a hairline crack in the solenoid (ignition) coil. A replacement coil did the same thing about two weeks after it was installed. The last replacement is still working after a couple of years.
As to why, I think that the resonant vibration at idle more closely matches the resonate vibration of the cracked solenoid so a momentary interruption occurs more often under those conditions. The warmth of the engine symptom also matched my situation.
Let me know if this helps!
Good Answers: 101
06/23/2009 11:15 AM
no coil... it has some kind of fancy coil/rail thing, with no spark plug wires.
Location: South East of Las Vegas just far enough to see the lights but far enough to not hear the coins falling
06/23/2009 11:42 AM
One Jeep guy to another I just want to say Congrats on it fixing it self and good for you to be out in it in the rain. I am a desert rat and we get very little rain. However when we get it we all head for the mud. I think your air filter is just on the edge of being too restrictive and the rain may have taking it to the air flow limit.
Rule number one; Never ask a question unless you are prepared for an answer that you may not like.
Good Answers: 101
06/23/2009 12:32 PM
Thank you fellow jeepster, I'll pull the air filter tonight and have a looksee... I doubt that It could be causing a restrictive issue, as it is a Air-Raid intake, with a K&N racing filter, but I'll take a look none the less (not that I would be able to see anything as the water has all evaporated now).
Its also got one of those "Tornado" throttle body spacers, and a Banks Stainless racing exhaust.
I am absolutely sure that the Idle issue is strictly electrical, and I am also sure that The cause was not anything in the engine compartment, as I do live in Oregon, and drive on roads that looks like rivers on a regular basis in torrential downpours. this problem was absolutely due to the water finding its way into all areas of my dashboard via the absence of a roof.
What links the idle to the speed? What under the dashboard could malfunction to allow all normal operation and great performance, Idle while rolling, but not sitting still.
Not the breaks, not the battery, not the airflow... Is the only place they are connected in the OBC? IF so, might my OBC have gotten wet? Shouldn't it be in a sealed container of some kind?
06/23/2009 12:51 PM
Our jeeps are set up very much a like. And I am lucky enough to only get into ground water and some sandy mud. I am envious of your area but I could not give up rock crawling.
If you want to see my area look at You Tube -PNO- rock bottom. My Rubicon is the white one.
The club site is PlayNiceOffRoad.com. For some water pictures....and no Jeeps don't float.
Good Answers: 101
06/23/2009 1:13 PM
LoL... "and no Jeeps don't float"
I hope to never find that out for myself, But i'll take your word on it.
06/23/2009 9:19 AM
Look at the throttle-position encoder. Its a potentiometer on the end of the butterfly valve. Good test is if you nudge the accelerator and can keep it running smoothly, the pot is crudded up on the low end. Talk to the guys at Autozone, et al. Easy to diagnose...
Also - slightly related topic: On the Jeep, if the battery has been disconnected or discharged to nothing, when you get it started - it won't run; need to depress the accelerator for 5 minutes or so until the ECM (engine computer) gets its act together.
Hope this Helps
Lynnbob33
Good Answers: 123
06/30/2009 11:46 AM
I would have to agree with your thought of the on board computer. You might want to remove the connectors on it ans reseal with some water resistant compound designed for this. Good luck.
Bob
09/19/2009 1:30 PM
it could be the O2 sensor - too old, too loose? or a wire fell off it? if its not sending the right message (air gas mixture) will throw everything off.
Good Answers: 101
09/21/2009 11:46 AM
Well, A while back I removed All the ground connection on the vehicle, cleaned and replaced. Also cleaned the battery terminals... Problem gone, I think all that water just caused some corrosion buildup on my grounds, causing some strange Electrical activity. Seems to be running perfect again.... Well, Except that squeaky belt in the morning.
I get to go put the hard top back on tonight... I fear the Oregon rainy season (Sept-June) is just around the corner.
Thanks for the help!
Register to Reply 17 comments
Anonymous Poster (2); bob c (1); JLMEALER (1); miketheboilerguy (2); mkruger21 (1); NotUrOrdinaryJoe (1); RVZ717 (7); the wrench (1); Yosemit3 (1)
