Previous in Forum: Fiber Optic Cable Testing   Next in Forum: Sensors for FRP Pultrusion Machines
15 comments
Laser Measurement Devices
06/23/2009 10:19 AM
For security reasons we need to measure every empty van that comes to the plant, they can be 53´ or 48´. The purpose is to verify that the inside length is the same as the outside length (to check for false walls). This has to be done fast and without having to go inside the trailer. Currently we have to get inside the trailer and use a 53´(or 48´) rope. Do you know of a reliable laser device that can do the job?
Thanks!
Good Answers: 62
Re: How do I get an accurate measurement of a trailer
06/23/2009 10:24 AM
07/16/2009 8:10 PM
I have one of the Bosch laser distance measuring devices and use it fairly often; it would easily do what you want and quickly. Realize, though, that Bosch really screwed up and only offered three measurement units: m, decimal feet, and feet, inches and fractions. You can get the thing for around $135 on Amazon.
Good Answers: 68
07/17/2009 9:01 AM
Hello someonesdad,
You say they screwed up an only measure in M, Decimal feet, and feet inches and fractions?
Does it actually matter to you what the measure use is? I would advise to measure in mm this will give you the size to the nearest 25th inch. Or measure and use a converter on-line to change from your measure to US or any other unit you want?
As long as you stick with feet and inches, OR, decimal, and do not try to convert between the two as you measure you will not get any errors. I can convert in my head between the two but I can see where it may be hard to convert to mm or 'English' Decimal units, if you are not conversant with them.
BTW, what do you mean by "Decimal feet"? A Decimal foot to me is 300 mm, or 30 cm.
Good Answers: 266
06/23/2009 10:28 AM
Google measuring devices laser.
06/23/2009 10:29 AM
How about this?
Good Answers: 62
06/23/2009 10:32 AM
Snap!
Jinx - you owe me a Coke
06/23/2009 10:42 AM
Will a lemon tea do?
Good Answers: 62
06/23/2009 10:49 AM
Tea - yes
06/23/2009 12:43 PM
I see a station which the trailer is pulled through which from overhead laser measure the front of the trailer , at that time several laser shoot the inside (door is already open) the two measurements via computer cross talk and the net wall is displayed. plus all trailers have numbers that is say bar coded and the history is log in as well , any changes , a red light flashes.... simple and auto and accurate.
whats for lunch??
Re: Laser Measurement Devices
06/24/2009 2:44 AM
Be carefull, I have seen on police TV shows how such false walls are errected "ONCE ONSITE"!!!
Also, side walls can be false.......
Be warned.
06/24/2009 9:07 AM
Go to www.opti-logic.com for the latest in infrared distance measuring instruments.
RHH
06/24/2009 10:44 AM
When I was a Realtor I used an unltrasonic device to measure rooms. It was hand held, battery powered, and worked very fast and accurately enough for your purposes. Among other places you can get one at Sears, Home Depot, or several other places that should do the trick for you.
06/24/2009 11:08 AM
X ray it.
Good Answers: 61
06/24/2009 6:04 PM
The Stanley TLM100 Tru-Laser is accurate to +/- 1/4" (6mm) at 100 ft. Operation is essentially point-click-read. Cost is ~US$100 at amazon.com.
Good Answers: 68
06/25/2009 6:14 PM
Hello Otto,
Here is two sites with laser measurement to check for false walls etc.
[PDF]
Untitled
File Format: PDF/Adobe Acrobat - View as HTML such as vehicles, trucks, boats and airplanes which can contain illegal substances. Carried on the belt, ... On the roofs of vehicles • Inside cabinets or closets in caravans or RV's ... overheads, fuel tanks and storage areas for false compartments. Freight Containers - Check walls for hidden panels, examine cross ... www.acoelectronics.com/pdfs/BusterAndCT-30E.pdf - Similar
[PDF] THE BUSTER K910B THE BUSTER K910B File Format: PDF/Adobe Acrobat - View as HTML to check seats on a bus, for example. Boats and Ships. Test bulkheads, cabin .... Behind the inner walls of tires on cars of trucks. • Inside cabinets or closets ... LASER MEASURING METER LRF-1. This unit is used to detect false walls ... www.sasrad.com/catalogues/buster.pdf - Similar
Hope this helps. Keep in touch please.
bb
Register to Reply 15 comments
Andy Germany (1); Anonymous Poster (1); babybear (2); edignan (3); EngineerRHH4 (1); Jim_Wright (1); Libra electric (1); ozzb (1); pwr2thepeople (1); PWSlack (2); someonesdad (1)
