Previous in Forum: Power Supplies and Loop-Powered Transmitters   Next in Forum: Level Measurement Instrument
Boiler Drums and Level Indicators
06/30/2009 8:29 PM
Dear All,
May anyone help advise the indicators configuration for boiler drum level indicating gauges in power plants in North America.
1). In one drum indicating, what is the most popular prortfolio of different kind of indicators, such as how may gauges glass, how many DP indicator, or Electrode Indicators, oe some other kind of indicators. And any advise about the manufacturer of each kind of indicators?
2). About gauges, it seems it need maintence frequently, so is it still be used in most power plants? Or they use some other independent to replace it and just keep it at serviceable state according to ASME codes.
3). About the maintence of gauge glass: how frequently it would need clearance, and what is the general expected life time of gauge glass. Also any advise of gauge glass manufacturer.
Thank you for your help and best wishes to all
Paul
Life Will Find A Way
Re: Boiler Drums and Level Indicators
07/02/2009 2:26 AM
Generally speaking a drum will have a differential pressure transmitter giving signal to drum level electronic controller in control room, a Truescale type of indicator that visually indicated and has contact alarms for control room, a level switch device that will cause instant shutdown on extra Hi or extra low water level, and one or two sight glasses, usually one at either end of the drum. Good practice is for every device mentioned to have its own pair of tappings and isolation valves on the drum, in case of malfunction/blockage/human error in opening after a shut.
Rok
United States - Member - New Member Engineering Fields - Chemical Engineering - New Member
07/02/2009 8:54 AM
I believe that code requires a gauge glass on the boiler drum, in spite of their frequent issues. The plant I worked at had 3 level transmitters for a 2 out of 3 shut down on lolo water level and a level gauge on each side of the drum. One was a magnetic type gauge (I believe a K-Tek (sp?)) and the other was a bullet glass sight glass. I believe the boiler code will spell out most of the requirements for you.
Hope that this helps, good luck.
Money doesn't talk, it screams in your face.
07/02/2009 10:44 AM
ASME section I still mandates at least one "direct visual water indicator" ie. gauge glass for HP steam boilers. Anything over a certain pressure requires 2 gauge glass indicators, one of which can be replaced by a continuously displayed electronic representation of the level in the control room.
Betomachine describes a very robust system that should be the standard for any high pressure boiler. 2 out of 3 voting is becoming more common for very good insurance against running the boiler dry or carrying over to a turbine, while reducing nuiscance trips due to a single failed device. This system allows for online maintnenace and calibration of all devices.
In summary, 3 DP transmitters for control purposes, 1 other remote level indicator (magnetostrictive, capacitance probe, ...) to drive hard alarms and a single gauge glass (c/w viewing hood) to satisfy code. Gauge glass and "alarm" gauge can share a set of drum taps and all 3 transmitters can share a set of drum taps, as long as there are no intervening valves to isolate both at the same time.
Register to Reply 3 comments
Anonymous Poster (1); betomachine (1); tersla (1)
