Previous in Forum: How to Choose a Flowmeter   Next in Forum: Boiler Drums and Level Indicators
Power Supplies and Loop-Powered Transmitters
06/29/2009 1:50 AM
Why 24VDC power Supply is used as standard for all loop powered transmitters? there is other power supply can we used for loop powered x-mitters?
Re: Why 24VDC power Supply is used as standard for all loop powered transmitters?
06/29/2009 3:20 AM
24VDC just happens to be a nominal two lead-acid 6-cell batteries wired in series.
Any DC supply up to the limit of the device is OK. Some instruments will go to 35VDC, for example.
In all cases, follow the manufacturer's instructions.
Good Answers: 18
Re: Power Supplies and Loop-Powered Transmitters
06/29/2009 5:07 PM
Non-standard voltage used to be the norm. Thankfully, some time ago a group of manufacturers got together and decided on something called a "standard." Life for people who work with such devices has gotten much easier since then.
The most valuable of all talents is that of never using two words when one will do. ~Thomas Jefferson
07/01/2009 9:25 PM
X-Meters, trnsducers, etc. for the most all run of 24VDC, that has become the standard, and since these are actually just transmitting Millivolts back to the Data Control System they do not require an extreme amount of high voltage, to perform their function, these transmitters are powered by 24 VDC but only output, any where from 4-20 Millivolts for a read out, in some cases the Millivolts are higher such as 5 to 30 but the standard is 4-20, this keeps things pretty standard and easy to find comparable brands that are interchangeable,
“A common mistake that people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools.”: Douglas Adams Quote
Register to Reply 3 comments
EElectrician (1); PWSlack (1); vmgarcia (1)
